| Erratic A/C Hello Everyone I'm new to the forums and have a problem with my 06 Chevy 3500 Duramax. The A/C will be working fine then the mixers must get the wrong signal and it changes from cold air to heated air. Sometimes just the passenger side is affected sometime both. Usually I turn off the truck and restart and it's back to cold air. I have removed the fuse for the a/c circuit for awhile and reinstalled but that did not help....any ideas? Taildragger |
| Welcome to the forum and howdy from TEXAS. My bothers HD was doing the same thing so when it happened once he turned up the heat all the way then he put it back to cool and it fixed it. It's a electronic part that's messing up you might call the dealership and see if there is a recall on it or service bulletin. Good luck! GMC |
| Thank you GMC...we'll give that idea a try. |
| don't you have 5 yrs 100,000 miles?
| I was pulling a wagon load of soybeans today and was running the a/c and the passenger side started putting out hot air so I turned the temp control all the way up as suggested and then back down and sure enough it changed to cool air. So I guees I'll call the dealer since it is covered by warranty. Thanks for all the help taildragger |
| TD I could use a rep point. Just kidding im glad my info helped you out now when you have it fixed get the name of the part because there has been some other members having that same problem even try to find out where the part is located say you might even ask them how much the part cost. Thanks! GMC PS-Since your a new member here what us veterans like here is when a member lets us know what fixed the problem. |
| need advice on erratic cold idle | duckle1 | Chevy Truck Forum | 8 | 03-12-2008 07:05 PM |
| Erratic Temp gage??? | MrBones | Chevy Truck Forum | 5 | 05-07-2007 07:30 PM |
| Erratic Fuel Gage | lb23 | Chevy Truck Forum | 5 | 03-31-2007 10:39 AM |
