| | #11 | |
| Full Member Join Date: Sep 2009 Location: Illinois
well thanks guys hopefully its compatible. i ll have to go check the wiring connectors to make sure | |
| | #12 |
| I found a little info you had better pay attention to. So I was curious as to this 95 being differant thing. It appears that the 95-97 models have what is called a PWM Pump system. Pulse Width Modulation, so check them out very closely. So now, I'd like to say, get the 98 or Newer to be on the safe side. Goes to show, you learn something new everyday. I kinda feel like I should have known this already, but I just happen to have done a bit of research and found it out.
| | #13 | |
| | #14 |
| Yeah, what I said, "WOW". Crab confirms that 95 does set all alone as its very own, so a 95 will only interchange with a 95. I know I shouldn't, but I am going to assume the reason for this is, 95 is the first year for PWM pump, but its also the last year of TBI, then in 96 GM went to SFI (Sequential Fuel Injection, which is Multi Port) so the ECM would have changed which is likley why the 95 stands alone, then if thats the case, you could also assume 96-97 will only interchange with themselves. I dunno for sure, just guessing.
| | #15 | |
thats what i would guess. apparently i better hope this is a 98 tranny. | |
| | #16 |
| do you know of ne websites for diagrams of a tranny or resourceful information. bc i plan on rebuilding my original in the future |
| | #17 |
| Just a bunch of places trying to sell "how to" books. Then there is this place that gives a diagram, but unless you know what you are looking at its not much help. https://www.wittrans.com/Schematic.a...0E/4L65E/4L70E Then you can click on each section it will break it down to a larger view per section.
| | #18 |
| Senior Member Join Date: Sep 2009 Location: MIchigan
| Hey hotrodpc after reading what you wrote got me interested so i did some diggin and found there is no difference it the drive lines of a 96,97,98 4wd truck the motors and trans are interchangeable though there were small tweaks between the years the internals were modified in 97 for better efficiency and reliability and in 98 the shift points were and TCC lockup were changed by 200 RPMS to help alleviate that lovely chugging when going up the slightest hill but the programming for running them remand the same. |
| | #19 |
| True on all that, but what about the PWM Pump in the trans and how will that affect the electronics? I understand that PWM Pump is for 3 years 95-97.
| | #20 |
| OK wow i've been getting bed data for some reason this is right as far as i know 95's and 96's stand alone a trans from a 97 will fit a 98. 95 was the first year for the PWM pump but the electronis were differnt. Then in 96 when the went to the vortec they changed the pump design and electronics. Then in 97 they changed the trans yet again. the pump remained the same the bell was different and they went to 133mm converter They added solenoids and they went to the EC3 programing system witch changed the input and output feed to the ECU and that remand the same in 98 so as long as the trans comes from a 97 or 98 it will work. |
| tranny problem or tranny swap | dondon3 | Chevy Truck Forum | 6 | 10-20-2008 07:25 PM |
| 1/2 ton vs. 3/4 tranny | cwenisch | Chevy Truck Forum | 2 | 05-24-2007 03:53 PM |
| aux. tranny | billiards | Chevy Truck Forum | 0 | 07-19-2006 03:19 PM |
| i need some help tranny help | ksmalloryusmc | Chevy Truck Forum | 5 | 06-05-2006 12:45 PM |
| v-6 tranny? | celicagt4 | Toyota Truck Forum | 1 | 01-06-2005 01:10 PM |
