Old 09-23-2009, 12:59 PM   #1
Jon03HD's Avatar
Jon03HD is on a distinguished road
thermostat?
the chip i am getting requires a 180 degree thermostat, i am wondering since the one if have now is 187 if that 7 degrees will make much of a differance if so what will it do? i
in order to purchace the 180 i have to use the chips website i cannot find it anywhere else, but i did find a 160 but that might be too low since winter is coming.
Any help would be greatly appreciated Jon
Jon03HD is offline   Reply With Quote
Old 09-23-2009, 01:20 PM   #2
Crmzendrgone's Avatar
What kind of chip is it? I would assume they have required a certain tstat after doing the research to know that engine performs where it needs to with that chip. I know newer engines are really sensitive to how every little aspect affects it. Believe it or not but how cool the engine runs plays a huge deal in fuel economy. Maybe that's the reason the chip needs it so it can run the parameters it needs.
Old 09-23-2009, 02:14 PM   #3
have you tried www.summitracing.com they usually have that sort of thing at a good price?
Old 09-23-2009, 02:48 PM   #4
Jon03HD's Avatar
it is a jet stage 2 chip it requires, open flow exhaust, the thermostat and it is supposed to be run on 91 octane.
Old 09-23-2009, 04:37 PM   #5
crabtruck's Avatar
So did you test your tstat to find out when it really opens,
generally not super accurate. You might have a 180.
Old 09-23-2009, 05:14 PM   #6
I have a 160' stat on my truck because of my chip and I have seen on a hot day if I didn't have that stat stuck in traffic my truck would have over heated I would get the right stat I have also heard that one can get a 170' stat so you truck will still run good but not use too much gas. Plus a Jet stat shouldn't be that much if you can get one from them the s/h should be dirt cheap but I would call www.Summitracing.com.
Old 09-23-2009, 06:01 PM   #7
I used to buy 180's at napa
Old 09-23-2009, 06:07 PM   #8
Curious what would be a benefit to run a 160* in AZ during winter.
Old 09-23-2009, 06:34 PM   #9
I really don't know about that but like I wrote you can get a 170' stat and it shouldn't affect your gas mileage.
Old 09-23-2009, 07:40 PM   #10
Jon03HD's Avatar
ok i will check napa for the 180 but the guy i bought it from said he had a 180 but wish he had gotten a 160 so im not sure what to do i might try to find a 170 like gmctrucks said.
Tags
180, chip, thermostat
thermostat mr.bigs Chevy Truck Forum 13 04-25-2009 08:46 AM
Thermostat 160 or 195? billk Chevy Truck Forum 9 07-10-2008 08:05 AM
thermostat problem jasonv100 Chevy Truck Forum 3 11-03-2007 01:39 PM
Thermostat problem again PickUpGirl787 Chevy Truck Forum 31 10-17-2007 06:49 AM
Thermostat question tims84k10 Chevy Truck Forum 4 08-15-2007 08:26 PM
