| Bad oil pump? I have a 05 Chevy Silverado 2500 HD with 50K miles. I had the oil changed on Saturday and this morning while driving to work the oil pressure went down to zero and the engine started making a "knocking" sound. I had it towed back to the place where they changed the oil and the mechanic there told me that he's 100% sure it's the oil pump. He also said that this is a common problem for these engines and the at he has replaced quite a bit of them. He told me he would have to replace the oil pump and the lifters. Has anybody had an issue with these oil pumps? Is it a common problem? I would appreciate any feedback thanks. |
| what engine , shd |
| It's a 6.0 |
| never herd of bad oil pump on that engine , did you check the oil level before it was towed back , might be trying to cover there own butt . and once it starts knocking it might be a goner shd |
| The oil level was fine I checked it before I sent it back. |
| What's the warranty situation on the vehicle? I would think that being only 4 years old and with only 50k on the clock the problem might be covered under warranty.
| Only two things I saw related: If oil pressure had been previously observed at a much higher value, then a leaky oil pump pickup screen O-Ring may be leaking. . ![]() |
| If it was fine before the oil change then I would suspect something at the shop, just because the oil pump goes bad does not mean the lifters are bad, do you have somewhere else you can take it? for a second opinion? don't you have a 5yr 100,00mi warranty
| Well I took it to another shop they say it's definitely the oil pump. But there is no way to prove the service shop did anything wrong. |
| fuel pump | kenarmy2001 | GMC Truck Forum | 6 | 03-27-2009 04:57 AM |
| Fuel pump? | Admmg | Chevy Truck Forum | 6 | 10-08-2008 09:57 AM |
| HELP S10 4.3 installing water pump , cant get water pump fan off | STRAYDOG | Chevy Truck Forum | 6 | 01-12-2008 01:26 PM |
| 94' Suburban ABS Pump ??? | 450MAGNUM | Chevy Truck Forum | 1 | 09-05-2006 10:30 PM |
| fuel pump | sean | Ford Truck Forum | 3 | 10-27-2004 10:37 AM |
