| my boyfriend just bought a 93 chevy silverado they changed tranny because u had to manully shift it. but after changing it u still have to. we talked to a guy who rebuilds tranny and he said if the speed op. don't work it won't shift right. can anyone help we can't figure out to fix the speed op. they tried everything they have thought of. |
| Senior Member Join Date: Feb 2009 Location: Okauchee, WI
| Is your truck 2wd or 4wd? Does your speedometer work? Do you know what tranny you have? Need a bit more informaton.
__________________ '94 Chevy Silverado Z71 Xtra cab 4x4 350cid 4l60e auto |
| 2wd no the speedometer don't work. that is what i meant. they checked the fuses and some kind of box in the dash. 4l60 trans. the tranny is out of a 99 chevy. we changed the tail shaft but it still didn't work. |
| I would think that the 99 is a 4L60E. I believe that needs a computer to run it. I think 93 was still a 4L60 no E for Electronic.
| thanks for the help |
| Senior Member Join Date: Sep 2009 Location: MIchigan
| X2 on that you can't put a 4L60E(94-??) into a 4L60 truck(91-93 it think) especially if the trans came out of a 99 the electronics are worlds apart. Sounds like your gonna have to find a trans outta a 4L60 truck or a older vacuum controlled 700R4 will work as long as the speed sensor in the housing is compatible with the wiring on the truck |
| You're right Dragon... Can't put a 99 tranny in a 93 and expect it to work without the PCM.
| so if i get the computer out of the newer truck and the motor is the same will it work then |
| It's not quite that simple... The PCM is going to need inputs that your 93 just isn't built to give it.
| No more than likely I don't think the trans will work with out the engine out of a 99 or later and the PCM. Because you truck being a throttle body injection truck and starting in 96 they went to full sequential fuel injection I don't think even if you got the PCM the trans provably still wouldn't work because those PCM's have specific programing the read engine rpm's engine load vehicle speed and so on and so forth to decide when to shift up, down and lock the torque converter. Basically what bernie said |
| 88 chevy tranny 5spd trouble | 88chevy350ss | Chevy Truck Forum | 11 | 03-27-2009 07:51 PM |
| tranny problem or tranny swap | dondon3 | Chevy Truck Forum | 6 | 10-20-2008 07:25 PM |
| tranny trouble? | razer900 | Chevy Truck Forum | 5 | 05-01-2008 05:01 PM |
| Automatic tranny problem,trouble shifting | DEP | Dodge Truck Forum | 3 | 03-01-2007 01:19 PM |
| GM is in trouble? | Beaver3000 | Off-Topic | 46 | 05-21-2006 05:55 PM |
