| Junior Member Join Date: Sep 2009 Location: Chandler, AZ
| 2003 Chevy Tahoe So randomly the power door locks, power windows and power mirror have stopped working on the Front Passanger door of my Tahoe. The turn signal in the mirror still works but all the power things have stopped. All the other doors and windows work. Its just this one door. I've looked online and seen some people with similar problem. I checked the wires in the door jam and nothing is pinched or spliced. I removed the door panel and nothing looks out of place. I've checked fuses and all other doors work, just problem with this one. Any suggestions? Don't want to spend an arm and a leg. |
| Welcome to the forum golf. You didn't specify whether the lock and window failed using the passenger as well as driver side controls. If that's the setup w/ wires DkBlue,Brw,Tan,Org I would suggest following the Tan and Org from the door to the Right IP Fuse Block where they are patched in on one connector and out on another on their way to the CB (RtDoor Circuit Breaker) in the Body Relay Block. Since you say the rear door works fine, I doubt it's the CB so you are looking at the power or data lines. Unless the FPDM has gone bad. |
| 1999 Chevy tahoe 4wd | gettembuilt | Chevy Truck Forum | 3 | 12-12-2008 08:56 AM |
| 1998 2dr.chevy Tahoe | tommytahoe | Truck Classifieds | 0 | 12-18-2006 04:41 PM |
| Rough idle and Stutter on acceleration 2003 Tahoe 5.3 Vortec | jnettrecker | Chevy Truck Forum | 17 | 12-16-2006 08:30 AM |
| 2000 Chevy Tahoe | smokejumper0902 | GMC Truck Forum | 0 | 07-28-2006 06:45 AM |
| 99 chevy tahoe | gortiz | Chevy Truck Forum | 0 | 02-03-2006 08:40 PM |
