| | #21 |
| Full Member Join Date: Oct 2009 Location: Washinton State
| Kind of having what looks like the begining of the same problem with Truck (same year and motor). Gonna go threw the filter and try the cleaner. Tripower428 do you ever have darker smoke? Ever had service engine light come on?
__________________ "Better than power over all the earth, better than going to heaven and better than dominion over the worlds is the joy of the man who enters the river of life IN A CHEVY DIESEL!." ![]() |
| | #22 |
| Full Member Join Date: Mar 2009
| put a new fuel lift pump on today, still has the same issue as far as the "shutter", But have not gotten it to stall after warm yet. Still testing to see if this had any affect. Square357, Yes, I do also have darker smoke as well, nothing like the big white cloud when first started. And yes I do also get a check engine light, but when I shut off the truck and restart it, no check engine light. When I get the check engine light it is always when I am on the freeway and higher speeds 70 +, the truck seems to run ok, I just get the light then after I shut if off, light goes away |
| | #23 |
| By the way, ran through the tank of fuel with the diesel injector cleaner in it and don't notice anything different. |
| | #24 |
| Don't understand why codes not being pulled by you guys when aware the check light came on - especially on an OBD-I. It's like skipping free answers or help ?? |
| | #25 |
| I did check the code, it says a "gear ratio problem". I just don't know how that relates to the issues I have. |
| | #26 |
| is it code 86?? 86 code "low ratio error" if so here is a borrowed post on a 95 "Try r&r'ing the two speed sensor connectors on the transmission, driver's side - each is a two-conductor plug. Has to do with engine input speed vs output shaft speed, and may be intermittent connection"
| | #27 | ||
Chev's term not mine. Mounted on the rear of intake manifold. Busy filter: 2 stage fuel filter, water sep, water detect, water drain, and fuel heater. 3 fittings: in from lift, out to inj, third to drain valve on thermo housing. Quote:
To drain water from "manager"/seperator put a catcher under drain hose. Open drain valve, then start and run 1-2 min or until clear fuel seen. Close drain valve and stop eng. Didn't mention if "water" light, aka "service fuel", comes on at key/bulb check. Sometimes that sensor gets stubborn about going off and needs to be removed and tip wiped clean. Don't think it would have been a 86-lo or 87-hi because those would stick it in 2nd gear. An 85-undefined ratio would block TCC though without forcing 2nd. . ![]() . ![]() | ||
| | #28 |
| Still have the hard start and "shutter" issue but the check engine issue has been fixed. It was a couple issues. 1) replaced transmission speed sensor. 2) replaced turbo waste gate solenoid. One part at a time..... |
| 94 Chevy, cluster issue? | tripower428 | Chevy Truck Forum | 6 | 10-18-2009 05:23 AM |
| 96 Chevy Headlight issue | SilverK96 | Chevy Truck Forum | 10 | 11-13-2008 12:20 PM |
| Chevy new HD diesel . Anyone seen one? | chevyguy | Truck News (headlines) | 3 | 02-28-2007 01:08 PM |
| '94 Chevy Winshield Wiper Issue | cookcs | Chevy Truck Forum | 8 | 12-07-2006 09:47 AM |
| 6.2 liter chevy diesel | chevyguy | General Truck Forum | 10 | 07-05-2006 10:51 PM |
