Old 10-07-2009, 02:31 AM   #1
moon23 is on a distinguished road
Unhappy 97 k1500 brake issue
Just recently acquired this truck, and have some issue to resolve the first is a brake issue.
Have just completed putting on new front cals & pads, rear brake cyl, and a master cyl. The lines are okay, all away around the truck. I have good bleed at all 4 point and have bench bled two mc and still have a soft or no pedal under power.
It pumps up fine in off position,& holds pressure, but the moment I power up pedal goes to the floor. I heard everything from p.booster, proporionate valve sticking, to a total replacement of the kelsy-hayes abs module.
I'm assuming that someone out here can help narrow this down as I've run out of ideas of what it is.
I forgot to mention, that while two man bleeding, that I notices that under power and pumping the brake, that the rear portion of the mc reservior for a lack of better words, perculates.
Thank you in advance for any info or ideas to look, as I have run out of both.
moon23 is offline   Reply With Quote
Old 10-07-2009, 02:38 AM   #2
Case 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud of
You still have air in the system. If you have the RAWL system you could try bleeding it by backing off the outlet pipe nut a few turns and pumping the pedal. That system can be a real pain to get all the air out.
Old 10-07-2009, 02:45 AM   #3
Sorry Case,
Backing off the outlet pipe nut????? Exactly, where is that located????
Thanks,again
Old 10-07-2009, 03:04 AM   #4
If you do have the RWAL system the unit sits below the master cylinder and above the inner fender with a multi-pin plug connector to it. There is a single outlet pipe from it going to the rear axle along the frame rail. It is the nut on that outlet pipe.
May not help but worth a try.
Also read through the thread below by km1980.
Old 10-07-2009, 05:33 AM   #5
^^^agreed make sure there is fresh fluid at every bleeder
98 GMC Brake Issue Brock GMC Truck Forum 4 07-05-2009 06:34 AM
88 k1500 oil presure issue .ben Chevy Truck Forum 4 05-08-2009 03:03 PM
Brake Bleeding Issue SilverK96 Ford Truck Forum 11 10-09-2008 08:02 AM
Tranny issue 96 K1500 4l60e Get Bent Chevy Truck Forum 2 07-14-2008 09:25 PM
1990 GMC K1500 4x4 and brake problems mbarcher GMC Truck Forum 4 02-26-2007 05:06 PM
