Results 1 to 5 of 5
Thread: 1989 chevy 1500 AC Vent problems, head blinks
    Oct 2009
    Michigan
    6
    Hi, I am having a problem with my vents not working right.
    The control unit (digital) just blinks at me for both
    the head/feet selection and hot and cold.
    I already replaced the control unit 2 times and that did not fix the problem.
    Someone told me it could be the actuator motors
    but i just tried one from a junk yard and it didn't change
    but i have no idea if it was any good or not.
    I didn't want to spend 88 bucks for a new one at the dealership for a blind check.
    When i select the hot/cold after the selector gets to a position that i select
    the motor still runs until it reaches full open or cold.
    Any ideas? i don't feel like pulling my whole dash and tracing every wire individually!
    Thanks
    Oct 2009
    Michigan
    6
    Would anyone happen to have a wiring diagram for the HVAC system?
    I have one of those Haynes manuals but the wiring diagram in that
    does not correspond to the actual wire colors in the truck.
    Sep 2009
    25
    I have the original wiring manual for an '89 GMC, should be the same.
    Oct 2009
    Michigan
    6
    could you post it please?
    crabtruck's Avatar
    Jul 2007
    5,566
    When it does get posted, be sure to only use it as a guide.
    I have looked at hundreds of drawings and have seen very few
    that are correct. My favorite is when the publisher puts out
    a correction that changes the part that was not wrong.
  1. 1997 Chevy 1500 electrical problems
    By hard420core in forum Chevy Truck Forum
    Last Post: 11-26-2011, 01:44 PM
  2. a/c heat vent air control problems
    By bergfurher in forum GMC Truck Forum
    Last Post: 05-10-2010, 05:37 PM
  3. 98 Chevy w/t 1500 problems.
    By smilexelectric in forum Chevy Truck Forum
    Last Post: 02-02-2009, 08:06 PM
  4. 97 chevy 1500 heater problems
    By boatz068 in forum Chevy Truck Forum
    Last Post: 12-03-2008, 09:11 PM
  5. 89 sierra vent problems
    By batmanwb in forum GMC Truck Forum
    Last Post: 07-11-2008, 02:51 PM
