| Full Member Join Date: Sep 2009 Location: Winston Salem, NC
| front shock install Hey ya'll. I just installed front shocks on 96 silverado. never done it before- It went fine but have a question someone with more experience can answer. How tight do you tighten the nut on top? Thanks in advance. Slide |
| shocks you generally run tghe nut down till it bottoms out ,to lock the nut . ![]() |
| till anything you try can't budge that bish :-) |
| there should be a flat spot on the top of the shaft you can grab to tighten the nut to keep the shaft from turning.
__________________ None of the secrets of success will work unless you do. |
| thanks, I was hoping to find a torque setting in Haynes book but they gave almost no info. I will run it down to the bottom. I called a repair shop here, they wanted $500 to install all four. I think the fact that more people are holding onto their used cars (not buying new cars) the repair guys are ******* up the labor costs. thanks again for the quick come back. Sliiiiiiiiiiiiiiiiiiiiiiiiide |
| Read the instructions that came with the shocks and most likely you'll find that they say to tighten down until the bushing diameter equals the washer diameter, and no further.
| Agreed you crush that bushing beyond what it is meant to be at, you'll prematurely cause it to fail and you'll have a knocking sound coming from underneath every time you hit a bump or jounce the suspension.
__________________ |
| shocks are in Thanks to all, I appreciate each response. I ended up using a kind of combination of a couple of ideas I heard today. One mechanic said to put 15 lb pounds of torque. Another said to sqeeze the rubber until it is the same diameter as the upper washer. I will keep an eye on it as I don't that I came up with the right answer. |
| What are the best shock absorbers? | 02-Morland | Chevy Truck Forum | 12 | 12-21-2009 12:03 PM |
| 96 Z71 Shock Question | SilverK96 | Chevy Truck Forum | 4 | 06-28-2009 11:45 AM |
| Shock Reccomendations | Cheyenne89 | Chevy Truck Forum | 16 | 09-05-2008 07:02 AM |
| on the hunt for some front dual shock hoops | chevyman_03 | Chevy Truck Forum | 1 | 08-22-2008 04:53 AM |
| Front Shock rattle 0n 05 Silverado | Herleman | Chevy Truck Forum | 4 | 07-07-2008 06:48 AM |
