Old 10-19-2009, 07:39 PM   #1
rlander06 will become famous soon enough
1995 Chevy 2500 Tranny or electrical
I have a 1995 Chevy 2500 PU with a 350 with a tranny problem.
I went about 3 days with no problems and then the tranny jumped out of OD and went to 2nd gear. The speedo and tech went down to zero but the truck was stll moving. I pulled over and checked tranny fluid it was full. I took off with it in OD and went about 20-30 mile an hour and it jumped down to 2nd gear and the speedo and tech went to zero again. It drives fine in 2nd and also the light indicator for the shifter goes out or dim until I slow down. HELP
rlander06 is offline   Reply With Quote
Old 10-20-2009, 03:44 AM   #2
silverhairdeere's Avatar
i'am confused due to my age , if this is a automatic , even if the selector is in of the trans starts out in 1 then shifts to 2 than 3 then into od at a certain speed , since the trandy doesn't slip when you put it in gear , i think it's electrical , maybe lose or corrosion on the connectors . do a scan and pull some coads and post back on what you find out
shd
silverhairdeere is online now   Reply With Quote
Old 10-20-2009, 05:46 AM   #3
hotrodpc's Avatar
Wild *** guess here wo even thnking. VSS has gone bad an sending false info the ECM to give false info to Trans.
Old 10-20-2009, 11:31 AM   #4
crabtruck's Avatar
Welcome to the forum rlander06
Or the connector fell half off ?
Do some snooping at the wires underneath and under dash,
and pull codes too. Do search here for info on how.
Old 10-28-2009, 01:15 PM   #5
Trucks back on the road
I just got my truck back from the shop. What they did was traced all the wiring and found a bad wire from the fuse to the tranny. Repaired this and the trucks running fine again. Thanks for your help.
'02 2500 Duramax Electrical issue nato2120 GMC Truck Forum 1 12-04-2008 10:45 AM
Sold a 1995 Suburban 2500 for $500.00... thomasnchy Chevy Truck Forum 6 09-25-2008 12:10 AM
86 gmc 2500 electrical ssgtnelson Chevy Truck Forum 8 07-20-2008 10:15 AM
1995 Dodge Ram 2500 ROLLOVER ACCIDENT! myhorsemyrules Introductions 2 04-28-2006 07:17 PM
88 2500 tranny question littlekings Chevy Truck Forum 2 12-15-2005 05:21 AM
