Old 10-21-2009, 11:26 AM   #1
autoshopazn's Avatar
autoshopazn is on a distinguished road
ignition wiring
does anyone have or know what wire is for the key ignition. I want to disconnect that and put a switch instead of using the key. the wires coming out of the steering column look like they would go to the key ignition, but i need to know which one is hot and which one is for the trigger to the starter.
1990 Chevy C2500 350 5.7 V8 K&N Air Filter; Muffler doesnt seem to be stock; Stock CAT; All stock except for stereo system. Class IV Hitch and Prodigy Brake Controller; Falken Tires
autoshopazn is offline   Reply With Quote
Old 10-21-2009, 05:55 PM   #2
crabtruck's Avatar
Believe it is the purple unless you have a manual,
then it would be yellow to clutch pedal.
You may find it easier to modify, if you do your cut
down by the bulkhead connector, and easier to undo too.
Only need to cut one wire and install switch in that
if all you want to do is make manual crank deal
instead of the spring crank on key.
Why are you doing this ?
Old 10-21-2009, 05:57 PM   #3
Crmzendrgone's Avatar
I am assuming he is wanting the costume feel of a push button start.
Old 10-21-2009, 06:01 PM   #4
BernieB's Avatar
Or dad won't give him the keys...
Old 10-21-2009, 06:05 PM   #5
That might be closer to the truth. hehehe
Old 10-22-2009, 08:42 AM   #6
people these days. i can hot wire that model chevy faster than any other truck out there. they make everything so readily available to you. i started one with a single screwdriver one time. actually takes me longer to get into the truck than it does for me to get it going.
Old 10-22-2009, 08:49 AM   #7
ha! i can get into one in less than 30 seconds. guy left the keys in his truck with it running and i ...............ya know i don't even know if it was his truck!
i'd rather be hunting
Old 10-22-2009, 09:58 AM   #8
Is that why you can not leave your state?
Old 10-22-2009, 10:32 AM   #9
crabtruck's Avatar
I think the drawing in the post office is a good likeness.
Ignition Problem Oriley Chevy Truck Forum 3 07-29-2009 10:14 AM
Ignition solenoid wiring uranium67 Ford Truck Forum 3 07-22-2009 03:09 PM
Why won't the ignition key go all the way in? EdPDX Chevy Truck Forum 2 01-07-2009 06:01 AM
ignition? brad4eva Chevy Truck Forum 3 08-12-2008 07:42 PM
ignition mod marshalljc Chevy Truck Forum 9 03-09-2008 11:59 PM
