Old 10-23-2009, 08:19 PM   #41
threads merged to stop any confusion and/or double posts.
i'd rather be hunting
Old 10-23-2009, 09:02 PM   #42
crabtruck's Avatar
And a nice job of it too.
Old 10-24-2009, 12:07 PM   #43
lemontor is on a distinguished road
well i'm getting the TBI problems worked out but i've got to pull my codes and i'm getting 12, which is good, 15 which my truck is cool so.. thats good, and 32, which says "EGR circuit" and MAP (open). does anyone know about this???
Also to leolkfrm it's a 93 k1500 5.7. which youve aready guess most of that brother. THANX fellows
lemontor is offline   Reply With Quote
Old 11-02-2009, 04:24 PM   #44
Also to leolkfrm it's a 93 k1500 5.7. which youve aready guess most of that brother. THANX fellaz
Old 11-02-2009, 05:42 PM   #45
crabtruck's Avatar
32 code does not actually check EGR,
ECM compares what it's trying to get from EGR by looking at MAP.
Code will remain for 50 keycycles after actual fault, then self-clear.
Code sets after 2 failures of test at 10-25% steady throttle,
above 32mph, MAP 15kPa<>47.5kPa, desired EGR command > 93%.
Start by checking for good connection at MAP R-side by dist (3wire:Gry,Grn,Ppl)
and EGR solenoid (2wire:Pnk/Blk,Gry), then check vac hoses.
If applying a direct vac to EGR should be able to see it move with mirror.
closed<2", full open>8.5" .
May want to remove and clean EGR valve.
A search for EGR in forum threads will pull up a lot of info & experiences.
Old 11-03-2009, 11:24 AM   #46
Crmzendrgone's Avatar
This is the most helpful info. I have seen, seeing as how I was going to ask does a TBI have a MAF sensor. I too have the dreded 32 code but haven't found time to fix my own vehicle.
92 k1500 sport Chevy Truck Forum 5 06-26-2007 02:45 PM
Wheel Drive Problems 96 k1500 MORROWMUDDER Introductions 7 03-19-2007 09:57 AM
I would like some help with my 93 K1500 flathead52 Chevy Truck Forum 6 03-04-2007 08:25 PM
1990 GMC K1500 4x4 and brake problems mbarcher GMC Truck Forum 4 02-26-2007 06:06 PM
1988 K1500 Cooling Problems HELP boxcarcop Chevy Truck Forum 3 08-09-2005 12:43 PM
