Old 10-25-2009, 01:38 PM   #1
kcotruck is on a distinguished road
Misfiring after 45 minutes of driving..........
1995 GMC 1500 4.3L V6
2-3 Months ago I changed all the plugs, wires, dist. rotor, dist. cap, ignition coil and ignition module. Truck has been running fine, no misfiring on regular 20-30 minute drive to work. I have now recently been driving to school an hour away and the vehicle has lately been starting to misfire after about 45 minutes of driving. Seems to only be misfiring when cruising at 70 mph and giving it gas and sometimes even holding steady. I is like a surge when the accelerator is applied when cruising. Could this be a BAD ignition module or coil that is not working properly when it gets warm. Could this be a BAD distributor shaft (main part) I don't think the distributor is the problem but I'm not sure. The truck runs fine for the first 30-45 minutes and then gets touchy to exactly the accelerator is applied, you have to listen to the engine and how it reacts to accelerate with out issue.......Does anyone have any suggestions that might help with this misfiring issue
kcotruck is offline   Reply With Quote
Old 10-25-2009, 03:26 PM   #2
BernieB's Avatar
The check engine light coming on when this happens? Any codes?
It sounds to me like something is getting hot after about 45 minutes, and that could be anything from a bad coil or ignition module to a bad pressure regulator.
Old 10-25-2009, 05:04 PM   #3
I just had the ignition coil and ignition module tested at a local auto parts store and they said they were fine......I also had the dist. rotor switched out..... not sure what is next, maybe replace the dist entirely....a guy up there said his dad has a suburban that was doing the same thing and also had the transmission recently rebuilt just like me and they thought it was something to do with the transmission, they couldn't identify the problem though so that wasn;t much help............
Old 10-25-2009, 05:35 PM   #4
BernieB's Avatar
An ignition module or a coil can test just fine on a bench and then immediately fail under load or when hot. Unless they're sticking it in an oven and heating it up while they test it there's no way they'd find such a fault.
Old 10-25-2009, 06:37 PM   #5
if i understand this.....as long as you drive under 70 it runs fine?
Old 10-26-2009, 03:29 AM   #6
Mrcrowley's Avatar
Mrcrowley is on a distinguished road
Yup I have a scanner I set it active reading and drove it would misfire and the Service engine soon light came on and scanner read it then it went out which is weird came up a a number 5 cylinder misfire. So big question is do you get a Service engine soon light when it misfires?
2001 Chevy Silverado K3500
8.1 litre
1 ton dually Dump
Allison tranny
56430 mileage
2004 Nissan Titan LE crew cab
5.6 litre
B/T package
Mrcrowley is offline   Reply With Quote
Old 10-26-2009, 05:34 PM   #7
The service engine light does NOT come on....any way it could be the distributor shaft or even something electronic with the transmission?
Old 10-26-2009, 05:36 PM   #8
The driving speed has nothing to do with the problem, it happens at many different speeds.
Old 10-26-2009, 06:40 PM   #9
BernieB's Avatar
Okay, so no SES (but you might still have a code set)...
My gut instinct is that it's electrical, and that it's something starting to fail after it's been heat soaked awhile. The two best candidates for this are the ignition module and the coil.
But, I just thought of one more possibility... It's an oddball, but I've seen it happen...
How's your gas tank vent?
Back in the days of vented caps you would sometimes get a car in the shop with symptoms just like yours, and later find out they had put a non-vented cap on, which was then causing a vacuum to build up in the tank as fuel was pumped out, until the pump couldn't overcome the vacuum any more. The engine would die a bit, which was sometimes just enough to let a little air seep into the tank, and then the pump would get a little more gas and the engine would surge.
Like I said, it's oddball and a bit off the wall, but if your tank vent were blocked or crimped that could be what's happening.
Old 10-26-2009, 07:54 PM   #10
are you still using fuses for the injector rails? or changed to breakers? you want to use fuses
1988 Silverado k1500 z71 - runs great, for a few minutes. rkrizan Chevy Truck Forum 4 10-28-2009 03:04 PM
Ranger dies if not warmed for 15 minutes bcooling Ford Truck Forum 16 04-14-2009 08:53 PM
my dodge 360 is misfiring steve d Dodge Truck Forum 3 09-12-2008 08:02 PM
Help! 99 F250 7.3 drops dead after 2or 3 minutes Rich5202 Ford Truck Forum 5 08-20-2008 03:19 PM
1988 Silverado k1500 - runs great, for a few minutes. rkrizan Chevy Truck Forum 14 03-28-2007 06:20 PM
