Old 11-01-2009, 10:53 PM   #11
crabtruck's Avatar
I don't know what would be safe to call a comparable truck.
Which places don't list your truck ?
Makes a difference which smog rules and whether "robust" fuel system.
Some are using fuel tank pressure sensor and some are not.
I had thought the other relay was in the right IP fuse box
but it may actually be stuck to the side of the frame near second tank.
Follow the wires from second tank and see what you see.
You would be in the neighborhood checking for good connections anyways.
Old 11-03-2009, 03:20 AM   #12
Mrcrowley's Avatar
Mrcrowley is on a distinguished road
Well Like pep boys, advanced auto parts,VIP they list Chevy Silverado,3500,4x4 hd but not 1 ton,Duelly with 8.1 litre gas. Which means not sure if they are the same under the hood.As far as the other relay Ill look at that today I bet it is corroded or damaged if it is exposed to road salt and what not being on the outside.
2001 Chevy Silverado K3500
8.1 litre
1 ton dually Dump
Allison tranny
56430 mileage
2004 Nissan Titan LE crew cab
5.6 litre
B/T package
Mrcrowley is offline   Reply With Quote
Old 11-03-2009, 03:24 AM   #13
Mrcrowley's Avatar
Hey crab truck any idea how much fuel the primary tank would hold I am as of now just toping it off every few days but I need to drive it about 150 miles north not sure how much fuel the primary tank holds?
8.1 litre
1 ton dually Dump
Allison tranny
56430 mileage
5.6 litre
B/T package
Old 11-03-2009, 10:08 AM   #14
crabtruck's Avatar
Check your glove box for an RPO code K53 (Robust Fuel), parts are different.
Did you get error codes pulled ?
No idea on tank size but should be able to find online/dealer.
Here's another hint how important they can be, could save big $$.
Even though officiallly a slightly different truck,
seems close enough to pay attention.
Problem shows up under other ways but I don't see the TSBs.
Old 11-03-2009, 10:22 AM   #15
Mrcrowley's Avatar
No codes showed up and the Unit is a tcu unit said it on top ,Going to double check for second relay under hood then on the c chassis frame. Ill follow the wire's and then call the dealer about the tank capacity
8.1 litre
1 ton dually Dump
Allison tranny
56430 mileage
5.6 litre
B/T package
Old 11-03-2009, 07:37 PM   #16
crabtruck's Avatar
Odd no code, maybe as simple as a bad ground.
Old 11-05-2009, 10:11 AM   #17
Mrcrowley's Avatar
I also looked up enhanced code nothing Ill work on it this weekend . I am good at troubleshooting ...
8.1 litre
1 ton dually Dump
Allison tranny
56430 mileage
5.6 litre
B/T package
Old 11-06-2009, 02:22 PM   #18
Mrcrowley's Avatar
Ok crabtruck I was looking for the other relay and I followed the wire bundle back to the fuse box under hood the only relay I found besides one in junction box was this one in picture.This was on the outside of junction box/fuse box.Other wise I do not know where the relay is all wires go towards the junction box .All the other wires do not have a relay on them only one does. It is in junction box labeled f/Pump. Ohh and I unplugged plug to secondary fuel tank and checked all the wires for power one had like 2.14 volts on it that was it I ground the meter to the frame .
8.1 litre
1 ton dually Dump
Allison tranny
56430 mileage
5.6 litre
B/T package
Old 11-06-2009, 05:41 PM   #19
did you know a mac, or snap on scanner can read the sending units?
Old 11-07-2009, 02:22 AM   #20
Mrcrowley's Avatar
That would be great but it would cost as much to get a fuel sending unit as it would to buy one and I don't know anyone who has one besides repair garage. It would be great though.
8.1 litre
1 ton dually Dump
Allison tranny
56430 mileage
5.6 litre
B/T package
Tags
dual fuel tanks, wiring diagrams
Fuel Sending Unit jessewd10 GMC Truck Forum 2 04-06-2009 10:26 PM
In-tank Sending Unit Removal Question. J-Bob Bigz Chevy Truck Forum 6 12-07-2006 09:42 AM
fuel sending unit ? outdoorsman Toyota Truck Forum 4 09-13-2006 02:41 AM
help on fuel sending unit utah86gmc Chevy Truck Forum 6 03-30-2006 11:16 PM
duel fuel tank problem srw45 Chevy Truck Forum 0 12-11-2005 03:45 PM
