| Full Member Join Date: Oct 2009 Location: good ol' North Carolina
| i have a 1997 silverado 1500 2wd with a 5.7 vortec with 135,000. Recently i have been hearing a "clunking" noise coming from the rear end right before i come to a stop at about 10-15 mph. I do not feel the clunk i only hear it. The truck shifts fine and stops fine. i have installed new U-joints, the carrier bearing looks good and i have redone the front and rear brakes. Nothing in the rear end seams to be loose suspension wise. I have checked the rear diff fluid it is full. the guy i work with says what i am hearing is gear lash......anyone have any suggestions the noise is going to drive me crazy. |
| Try greasing the splines on your drive shaft yolk, GM had a TSB out on that problem
| i have done that but it did not do anything to help the problem....i just bought the truck in feb. so GMC have a recall on that??? |
| nope, just a TSB
| i would gather tsb is techniacal service bulletin? |
| yes it is, look it up it will tell the remedy for your problem.
| where do i need to look for the tsb, i cant seem to find what i am looking for |
| Auto Zone's website may have a listing
| im still stuck on what can be causing this noise it is driving me nuts |
| hang tight, some one else will be along later with other ideas on would could be causing it.
| 93' GMC Rear end noise | Nitroball | Chevy Truck Forum | 0 | 08-09-2009 01:08 AM |
| Rear end noise | hotdawg23 | Dodge Truck Forum | 12 | 07-29-2009 07:42 PM |
| Rear end noise? Like a grinding noise. | markparks1 | GMC Truck Forum | 8 | 11-08-2008 09:20 AM |
| rear end noise | rcarlos | GMC Truck Forum | 9 | 03-06-2008 10:39 PM |
| Noise from rear end | Itstali25 | Chevy Truck Forum | 6 | 10-24-2005 09:31 AM |
