Old 10-27-2009, 04:30 PM   #1
powellsd is on a distinguished road
Exclamation 91 K1500 5.7 rough idle
Ok i have a 91 k1500 with the 5.7 and i been having a sporadic idle after it warms up. I have researched it all over the place but havent really found anything that is leading me to the right direction. The truck has 188k on it and i pretty much replaced all maint items on it. I am getting it ready for winter and some hunting trips. Here is what i have replaced.
ICV, Cap, Rotor, Plugs, Wires, Coil, EGR, EGR Sensor, TPS, ICM, Fuel Reg, Fuel Pres is 11psi, Oxygen Sens, all vacuum lines, Fuel Filter, Did a vac test and no leaks from the smog machine, Ground wires in engine bay look good. Putting out 14-15v on the battery.
Ran a can of BG44k in gas, Seafoam in crankcase.
I am getting a good spray from the injectors at idle and when i rev the engine.
I have a new temp sensor and tstat but cant think that would cause my issues.
Anyone have some ideas on this?
I do smell gas fumes (more then one would think) when i take the air cleaner cover off...like it is overloading itself.
powellsd is offline   Reply With Quote
Old 10-27-2009, 08:24 PM   #2
when you did the vac test, was it at operating temps or when still cold?? you mention a new temp sensor but did not say that you had already put it on. just for clarification.
how does the throttle body look?? dirty and plagued with carbon deposits?? clean??
Old 10-27-2009, 08:36 PM   #3
Sorry did the vac test after it was warmed up. No i havent installed the new temp sensor yet, the TB looks good and i sprayed it down with carb cleaner.
I am gonna try to see if i can get my buddy scanning tool and hook it up to the truck as we are driving around. I did the check engine light code trick and that came up clean...
Old 10-28-2009, 01:36 AM   #4
Here I go again try a can of Seafoam the stuff really works good it might clean them injectors and leave them new again.
Old 10-28-2009, 03:59 AM   #5
chadwickthomas is on a distinguished road
when your engine is ideling and your moter is steady reving up and down at a pretty steady pace you need to unscrew your idle step up motor out of the side of your throttle body and clean the pendelum and port it screws into.IF it fluctuates slightly but runs real rough you have a vacuum leak somewhere check your intake manifold for leakage with eather but more likely it will be your egr valve pendelum not seating closed due to carbon build up in the ports.Also make shure under you throttle body is not clogged up with carbon if it is check vacuum ports comming out of throttle for carbon restrictions
chadwickthomas is offline   Reply With Quote
Old 10-28-2009, 04:24 AM   #6
I don't see a fuel filter on the list?
Old 10-28-2009, 06:34 AM   #7
I used a can BG44k and no dice..
I will look at that. Its not rough while driving just at idle
Sorry i changed the fuel filter.
Old 10-28-2009, 11:01 AM   #8
jremington59 has a spectacular aura aboutjremington59 has a spectacular aura about
I have the same motor in a 94 and I've had the same problem forever to the point that I've given up trying to fix it, lol....
I do have a bad exhaust donut with a bad leak and someone told me this can mess up the readings from the 02 sensor. Is your exhast bad at all in front of the sensor?
One other thing Im wondering about is a worn cam....
jremington59 is offline   Reply With Quote
Old 10-28-2009, 09:39 PM   #9
batty1214's Avatar
If you havent already, Pull the cap and rotor off of the distributor, and move the drive rod...... It's normal for it to move up and down a bit, but any side to side play will make it miss........ Also, the drive gear of the distribtor may be a little worn, and not letting it run like it should.... Thats what it ended up being on my work truck.....
Old 10-28-2009, 09:42 PM   #10
I thought about getting a new distributor for it, but looking at a couple of things first..
Thanks for the tip
Tags
rough idle, sporadic idle
rough idle vanhal Chevy Truck Forum 2 09-12-2008 05:41 AM
rough idle jspeedo Chevy Truck Forum 1 04-22-2008 06:52 AM
rough idle jarhead2001 Chevy Truck Forum 21 03-22-2008 09:57 AM
Rough idle bevanlane GMC Truck Forum 11 01-22-2008 10:02 PM
Rough idle utardcrew Introductions 2 05-25-2006 10:31 AM
