| | #11 | |
| | #12 |
| For some reason, yes, engines do seem to know what plugs are installed in them. Back in the racing days, when we'd take our hotrods to this place that would dyno tune them. They were expensive, and always required you to drop if off with a full tank of gas, and you go it back on empty, but they were good. They dialed everything in, recurved the dizzy, rejetted the carb etc to match your cam and it always did run well. I about died to find Motorcraft plugs in my SBC. I was PO'ed and figured they just put in what they had in stock to fit. Called them up and did some chewing. They said, No, Motorcraft is what they have found that runs best in hi perf SBC's and they were put in on purpose. Called my buddy up and told him what they did. He said, yeah I know, thats what they put in my car too, and them plugs have been in there for almost a year. His car ran very well and so did my truck. But at first I sure was not having any part of those plugs. I was later convinced they were right.
| | #13 | |
| Junior Member Join Date: Oct 2009 Location: Okinawa Japan till Nov, then Cali.
__________________ 2003 Chevy 2500HD - Ol' Red 1978 Ford F-150 4x4 shortbed - Mighty Whitey 1977 Chevy 4x4 shortbed- Ol' Hullie 1976 Chevy K20 4x4 - Warpig 1972 Chevy C10 1954 Chevy 3800 Papaw | |
| | #14 |
| Full Member Join Date: Oct 2009
| toto I wonder if we could get off this discussion of spark plugs and figure out what may ailing ToTo ? Thanx..Arnie ![]() |
| | #15 |
| toto Thanx and where might I find these O2 foolers...........Arnie |
| | #16 |
| This for a toyota but something just like it can be rigged up fo a Chevy O2 sensor bypass
| | #17 |
| ToTo Thanx Preacher, I'm not concerned about the lite on the dash. I'm only concerened about drivability. I'm open to ideas that would cure "ToTo". Take care....Arnie |
| | #18 |
| Senior Member Join Date: Aug 2009 Location: Northern California
| Arnie Alt, i humbly apologize for hi******* your thread. Bernie, well written, thanks CM65 |
| | #19 |
| OK the cats are part of your drivibilty. Without the cats the down stream o2s are seeing more HCs then there should be if a cat was in place. Therefore leaning out your mix or opposite. The o2 foolers sounds like a good thought.
| | #20 |
| WOW every now and then we get the heated debate about plugs!!!!!! since the problem appears to be in the open loop time period, I would check the temp sensor. also, back presure, or exhaust flow rate will affect the 02 sensor readings, without the cats, the ecm would need to be reprogrammed.
