| what year 5.7 will work in my truck? Does anyone know what year of 350 wil work in my truck? I have a 98 w/t 1500 witha 4.3 vortec. there is a 89 350 with a knock and blew smoke, i want to rebuild the 350 and swap the 4.3 out. |
| if you use the one from the 89 it will not be a vortec, unless you go buy some vortch heads to put on it. other than that i think it will work with a few modifications.
__________________ 96-GMC C1500 305ci 2WD K&N FIPK Cold Air Intake Rebuilt Motor (should have gone 350) and Trans 05 Nissan Xterra 4.0 V6 No mods so far Cost money to go fast...How fast do you wanna go? |
| i just need a vortech 350 then? is vortech even any good? whats the diff between the vortech and the other engines. |
| A vortec has different style heads. They will flow better than others within a similar price range. The only catch is they also require a different intake.
| just my luck theres a 89 350 that needs rebuilt and vortec heads for 50 dollars on cl and i dont have money. |
| you need more than just the heads and intake if you want to keep the factory injection and ignition system. the older engines do not have a crank sensor, so you will need to change the crank and modify the timing cover.
| bahh, ill just wait for a 350 vortec to show up. |
| think I can rebuild a seized motor? its a 97 burb 350 vortec |
| sure.......new bearings, possible crank replacement, bore or hone, possible piston replacement due to bore..............
| | #10 | |
see i wasn't completely sure thx for chiming in mudseeker
__________________ 96-GMC C1500 305ci 2WD K&N FIPK Cold Air Intake Rebuilt Motor (should have gone 350) and Trans 05 Nissan Xterra 4.0 V6 No mods so far Cost money to go fast...How fast do you wanna go? | |
| Work Truck | LAH | Ford Truck Forum | 0 | 10-23-2009 07:46 AM |
| What year is this truck? | bar10derchuck | GMC Truck Forum | 16 | 07-29-2009 12:01 PM |
| New work truck | mrjohnwayne | Ford Truck Forum | 35 | 10-02-2007 08:08 PM |
| Truck, bus tyre production up year-on-year in Jan (The Hindu) | trucknews | Truck News (headlines) | 0 | 03-17-2005 01:30 PM |
| Finalists for North American Car of the Year and North American Truck of the Year (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 12-14-2004 01:30 AM |
