Old 11-04-2009, 01:49 PM   #1
goatman is on a distinguished road
When i turn on headlights gas gauge drops
Hi, i have a 86 c20 pickup and when the headlights are off the gas gauge works fine but as soon as i turn them on, the gauge drops suddenly and stays there till i turn them off. Any help would be appreciated
goatman is offline   Reply With Quote
Old 11-04-2009, 01:53 PM   #2
1500cheyenne96's Avatar
1500cheyenne96 is just really nice1500cheyenne96 is just really nice1500cheyenne96 is just really nice1500cheyenne96 is just really nice1500cheyenne96 is just really nice
Sounds like you got a bad ground that is shorting out when you turn your lights on try checking the headlights ground and the gas gage ground also there is a main ground on the firewall i think that is held on by a nut and sometimes that nut comes loose
1500cheyenne96 is online now   Reply With Quote
Old 11-04-2009, 02:11 PM   #3
check the harness for a rub thru point along the frame
Old 11-04-2009, 06:47 PM   #4
crabtruck's Avatar
I would say you have a GOOD ground that is shortig the wire.
I'm with leo on this one for concept, might be either side of firewall too.
Before you get high tech with meters or get out the flashlight and magnifying glass,
have someone watch the gauge with the lights on and problem showing.
Jostle by hand the wires for the run from tank to gauge.
That might narrow down the area for you and is real fast.
If the gauge is not just dropping, but going all the way to empty,
You are looking for a blatant short, not where wires are somewhat slack.
Old 11-04-2009, 08:16 PM   #5
BernieB's Avatar
As an additional possibility, what's the condition of the battery and charging circuit? Are you getting a significant voltage drop in the system when the headlamps are on? Could be a weak battery or weak alternator.
Old 11-05-2009, 09:07 AM   #6
Thanks for the information gents, now i have a good idea on where to start.
Old 11-08-2009, 04:28 AM   #7
crabtruck's Avatar
Upon further reflection, I'm going to change my answer.
Check your system voltage as bernie suggested.
Check that all lights are working in all combinations.
If the above is ok, then something either in the cluster or
the mechanical operation of the switch is the problem.
Gauge would drop for one of two reasons: power loss to sender,
or grounding out of return from sender.
Ground wires are not traveling with the gauge wire for most distance
between the rear and dash/firewall.
Operation of switch will not change physical condition of wires to rear.
A short from a headlight switched hot wire will not provide a ground path.
This is true both under truck and in cluster.
Therefore I believe you are mechanically moving wires when using switch.
Look for the problem behind dash, quite likely find by "jostling" there.
Old 11-09-2009, 10:37 AM   #8
You're probably right. I checked all the wires and grounds in the engine compartment and everything there seems ok. I also had my son watch the gauge while i was under the truck moving all the wires from the sending unit and that didn't correct it either. I did notice that one of the previous owners changed the steering column in the truck and was thinking maybe they might of screwed something up inside the column somewhere or like you said maybe the light switch. I was about one step away from yanking every wire outta there and starting from scratch with a new wiring harness........then i priced one. Yikes!! i think i'll try to fix this one.
Old 11-11-2009, 01:16 PM   #9
Faxcion's Avatar
Faxcion is on a distinguished road
Hahaha! Good ol' GM keeping the American people scratching their head!
ИO COP ИO SŦOP!
Faxcion is offline   Reply With Quote
Turn turn turn... Tie rod end or whole shooting match? z07 Chevy Truck Forum 1 06-22-2009 02:08 AM
Help! 99 F250 7.3 drops dead after 2or 3 minutes Rich5202 Ford Truck Forum 5 08-20-2008 03:19 PM
Truck Jackknifes, Drops Steel Coils On N.J. Turnpike (WNBC) trucknews Truck News (headlines) 0 08-05-2005 05:30 PM
Fisherman chilled after truck drops into icy lake (Hinton Parklander) trucknews Truck News (headlines) 0 03-14-2005 03:30 PM
County drops tussle with state for Folsom land (The Sacramento Bee) trucknews Truck News (headlines) 0 08-04-2004 09:30 AM
