Old 11-04-2009, 09:34 PM   #1
aolteach is on a distinguished road
95 350 Chev won't start
Hi all. New here. I've researching this forum for almost two hours and what great info I've learned.
I'm trying to help my computer changed Dad with his truck. Its a 95 (94 parts) Chev 350. 2WD. Long box. This truck runs on gas and propane. Factory issued propane kit.
It's a strange problem. The truck only starts around mid day everyday. Even with warm or cold days. Always around 12:00. Later that evening, won't start again. Next day the same.
He gets gas to the TBI. Just nothing to the injectors. Or the injectors are not firing.
He's getting lots of spark. Put gas in Throttle Body and it runs fine until all the gas is gone.
He's replaced.....Injectors, fuel relay, fuel pump, fuel filter, fuel regulator, ECU.
We've been leaning towards something temperature / moisture affected. Or something that controls the injectors.
Any suggestions are greatly appreciated. I feel bad for my Dad as he's getting to that discouraged stage. He's actually pretty good with vehicles.
aolteach is offline   Reply With Quote
Old 11-05-2009, 01:29 AM   #2
shadygrady's Avatar
shadygrady will become famous soon enoughshadygrady will become famous soon enough
Now thats odd.New injectors and all.You get fuel to the TB unit but not out of the injectors.I`d check all the engine controll fuses and make sure everything is hooked up to the TB correctly.I had a loose wire blow my engine fuse and I got crank but no start and no fuel came out of injectors.However, you say it cranks at noon only now thats really odd,maybe its ready to go to lunch.I cant see temp or moisture affecting a TBI unit as they`re used all over in all climates.Is the new ecm designed for a gas/propane truck?Are you sure its switched over to gas?How does it run on propane?
1989 k1500 Cheyene 4x4,regular cab,swb,4.3 V-6.11`x 4`k&N Open element,TBI mods,smog pump delete,mechanical fan clutch to electric fan swap.flowmaster 2.5 dual exhaust.
shadygrady is offline   Reply With Quote
Old 11-05-2009, 02:58 AM   #3
Welcome to the forum and howdy from TEXAS. How many miles does the fuel pump have on it? If you ever change out the fuel pump buy a Delphi brand there much better than the other ones plus many of people have replaced theirs with a cheap brand only to remove it again after a week or sooner. Shady has some good questions.
Take care! GMC
Old 11-05-2009, 05:30 AM   #4
ecm temp switch in the head
Old 11-05-2009, 02:53 PM   #5
Just spoke with Pops. He's going to look closer at the ecm temp switch on head this eve.
Yes truck runs fine on either the gas or propane. Once it gets running......
Yes the ECM is designed for gas or propane. He had to give the serial number off the old one and they mathced it up. He spoke of the last 4 digits.
Thanks for the suggestions to this point.
Old 11-09-2009, 11:19 AM   #6
Changed both temp sensors. Still the same.
What a pain in the butt this has been. But we're not giving up.
Old 11-09-2009, 11:25 AM   #7
1500cheyenne96's Avatar
1500cheyenne96 is just really nice1500cheyenne96 is just really nice1500cheyenne96 is just really nice1500cheyenne96 is just really nice1500cheyenne96 is just really nice
Just a thought when he replaced the injectors did he hook the injectors up backwards on accident? had a friend do that to his truck and it wouldn't fire the injectors for some reason
me+shotgun equaled fresh meat on table
1500cheyenne96 is offline   Reply With Quote
Old 11-09-2009, 12:06 PM   #8
chevyguy's Avatar
Doesnt sound like temp to me, becasue after it starts it continues to run. When ti doesnt start i assume the motor is turning ove adn just not firing up? maybe fuel pressure to low? I would check the above mentioned fuel pump first .
USMC 92-96 USCG 98 to present
Old 11-10-2009, 08:43 AM   #9
There's has been a new fuel pump installed. The symptoms are the same as with the old pump.
And appears to be good pressure up to the TBI. Just can't get the injectors to open all the time. They only open up later in the day. Very intermitent.
We have somebody much more mechanically inclined coming to visit us to day with his tools...... We're crossing our fingers.
'89 Chev C1500 puff of oil smoke when i start shawn_huk Chevy Truck Forum 7 07-07-2008 09:25 PM
6.0L chev gas in oil? bullet man Chevy Truck Forum 8 03-03-2008 08:59 PM
'99 Chev ABS problem ryeja Chevy Truck Forum 13 01-24-2008 09:29 PM
I'm Looking for advice, 73-87 Chev box floor in 67-72 chev truck? dhashigu Chevy Truck Forum 2 07-06-2007 08:05 PM
Chev. truck jac Introductions 3 07-27-2006 10:19 PM
