Old 11-04-2009, 10:25 PM   #1
92chevyguy is on a distinguished road
92 wont start
I have a 92 chevy with tbi 350. It was running fine today and then it started bogging down like it wasnt getting fuel. So i replaced the fuel filter on the frame. Problem still existed. checked the injectors and they seem ok. changed the fuel pump and yet again the problem still is there..... Any ideas on what else it could be....
92chevyguy is offline   Reply With Quote
Old 11-04-2009, 10:44 PM   #2
BernieB's Avatar
Start looking at your "combustion triad" (air/fuel, compression, ignition) and see where it leads you.
In your case, we'll assume you have compression, so that leaves the air/fuel mixture and ignition left to check. You've already checked half of the air/fuel leg of the triad, so maybe you'll want to look at the "air" portion of that. How's the airflow? Clean filter? Nothing blocking the intake?
Old 11-05-2009, 01:16 AM   #3
shadygrady's Avatar
shadygrady will become famous soon enoughshadygrady will become famous soon enough
I could be wrong but this is my experience.Ive found most of the time with my vehicles ignition components wear out the fastest and most often.Ive never had to change a fuel pump and never had anything block or clog the intake track.I am however about to change the fuel pump on my iroc.180,000 miles and its still going,i just need to upgrade to a 255 L/hr.My friends stock pump lasted 200,000 miles.
If its a well maintained truck i.e. clean air filter,maintained fuel system its prolly a bad set of plugs,wires,cap,rotor or maybe an ignition module or coil.Ive had all of these fail on me.However when the coil or the module fail you should get a no crank situation.Good luck
Oh i just remembered and noticed your thred title was NO START.Do you have spark?
1989 k1500 Cheyene 4x4,regular cab,swb,4.3 V-6.11`x 4`k&N Open element,TBI mods,smog pump delete,mechanical fan clutch to electric fan swap.flowmaster 2.5 dual exhaust.
shadygrady is online now   Reply With Quote
Old 11-05-2009, 03:03 AM   #4
Welcome to the forum and howdy from TEXAS. What brand fuel pump did you buy? Check your fuel pressure. Now im not saying that im right but it's a idea. Shady don't forget to buy a Delphi pump look how long the OEM has lasted.
Good luck! GMC
Old 11-05-2009, 05:29 AM   #5
is it no start or running bad, might have pinched a fuel line putting the pump in, so you are chasing the original solution
Old 11-05-2009, 07:37 AM   #6
it stays running if you give it gas. but if you try to give it more gas it dies like its not getting enough fuel orr something
Old 11-05-2009, 07:42 AM   #7
BernieB's Avatar
Try giving it a bit more gas, and when it starts to die give it a shot of starter fluid. If it revs then it's not getting enough fuel or is getting too much air. If it still dies then it's getting too much fuel and not enough air, or has ignition problems.
Old 11-05-2009, 07:45 AM   #8
what if i try the idle control valve?
Old 11-05-2009, 11:20 AM   #9
i guess it runs great at about 1000RPMS while sitting in the yard?? if it seems to sputter and stall out without giving it any gas, you shuold check out the IAC. you may try removing it and cleaning it out before buying a new one though. should be 2 torx screws located on the back of the throttle body. it will have a brass colored, or in your case, black, that acts as a piston of sorts. do not screw it in but clean it up as well as the port in which the IAC feeds into. while there, go ahead and clean the butterfly in the TB. pay close attention to the back side of the throttle plate.
wont start when hot RL Hurley Ford Truck Forum 6 08-20-2009 02:55 PM
wont start at first tnbuckrut Ford Truck Forum 3 12-19-2007 09:38 PM
83 gmc wont start joeydeherrera54 GMC Truck Forum 7 11-28-2007 04:30 PM
y wont my truck start right away? eganracing Chevy Truck Forum 6 11-25-2006 05:57 PM
Wont start blue cobra 60 Chevy Truck Forum 3 10-18-2006 10:24 PM
