| which wheel cylinder repair kit? how do I know which rebuild kit to get? its giving me all this bore **** and 10" rear brakes? im looking at rockauto.com and my truck is a 98 chevy 1500 w/t 5 lug 2wd no posi. and how do I know if my rear shocks need replaced i, i was gettin it bouncing and stopped and it didnt bounce again after I let go. but the front will keep bouncing. |
| The best to do it pull it apart and measure it. But, I will make a guess for you. Since you are a V6 auto in a half ton, you are likely going to be the smallest one. If it were a V8, then it would be the bigger one. Sounds like your rear shocks are good, front ones need replaced.
| whats CYLINDER KIT,RR BRK w/VACUUM PWR BRK SYS(JB6) or HYD PWR DISC/DRUM BRK(JD6) do i have that. im just about to buy the kit that says rear |
| i think the jb6 is for a gas engine and the jd6 is for diesels shd |
| 98 1500 is going to be VACUUM PWR BRK SYS(JB6). you dont have hydralic assisted brakes on your 1/2 ton. |
| The JD6 Hydro boost would be all 1 ton trucks, gas or diesel and diesel in a 3/4 ton. So your is Vac boost for certain.
| Ok i bought 2 of them since they both need rebuilt. ![]() |
| Colorado/Canyon 4 cylinder/5 cylinder | songkrai | Chevy Truck Forum | 10 | 08-23-2009 02:05 PM |
| 4WD Switch Repair | 41canine | Chevy Truck Forum | 0 | 04-17-2008 12:52 PM |
| 2 wheel drive to 4 wheel conversion | frank3ks | 4x4 trucks / off road | 6 | 03-31-2008 10:30 PM |
| #2 cylinder not getting gas | jesusdrivesagmc | Chevy Truck Forum | 3 | 11-09-2007 08:39 PM |
| Wheel Question on my 4 wheel drive??????????????? | 92BlueZ71 | Chevy Truck Forum | 4 | 03-19-2007 05:06 PM |
