Old 11-10-2009, 11:29 PM   #31
Mudman88 will become famous soon enoughMudman88 will become famous soon enough
ok...so tell me more!hahaha. Im stuck at work right nowand cant get this issue out of my mind.
Mudman88 is offline   Reply With Quote
Old 11-11-2009, 06:36 PM   #32
Rago's Avatar
Rago is just really niceRago is just really niceRago is just really niceRago is just really niceRago is just really nice
Originally Posted by Mudman88 View Post
well..I looked at the actuator and the shift cable wasnt even hooked into it, so i put it all back together according to my book and it still isnt going into 4x4.THe actuator seems to be good, air goes in and air goes out, no leaks..I dont know what to do now. Its my girlfriends truck and I really dont want her driving it in the thick snow that they are calling for this winter in 2wd..What should I do guys?
Just gonna say you checked most everything I would have. I've owned a couple of these & two things go out:
1. The transfer case actuator (if it's clicking, it should be working)
2. The vacuum actuator that engages the axles. (This is where I would focus my attention)
I see you have already been through most of the troubleshooting, but I noticed from the quoted post that you didn't mention if the rod was moving. You should be able to see it move in & out when it engages the axles. On my old 83, everything seemed to be working, but the axles weren't engaging because of this problem. As a temporary fix to get me out of the trails I was on, I grabbed a pair of Visegrips, pulled the rod out, & locked it down. This engaged the 4wd, but I wouldn't recommend it as a permanent fix (unless you are a fix it with duct tape kind of guy, lol). The problem is that air can come in & out of the actuator & it still might need replaced. There is a rubber piece inside the actuator that acts like a suction cup & if there is even the slightest tear, goodbye 4wd. I hope this fixes your problem, good luck.
Rago is offline   Reply With Quote
Old 11-11-2009, 08:48 PM   #33
hotrodpc's Avatar
Nice to see you back around RAGO, Hope all is well !!! Hopefully your suggestion works for this guy, he's been trying hard to get it fixed, and I have not experienced this problem yet.
Old 11-12-2009, 02:21 AM   #34
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
some times i have seen the clips loose thier strenth and the cable just slides out and dosent engage the diff if this is the case simply bend the clip untill it holds the cable in place
PAPA BEAR is offline   Reply With Quote
Old 11-12-2009, 02:28 AM   #35
hotrodpc's Avatar
Mudman ought to be happy. He's getting people out of the woodwork on this one. I have not seen P Bear around in awhile either.
Old 11-12-2009, 07:47 AM   #36
Crmzendrgone's Avatar
Crmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant future
I have never seen Papa bear so glad to know some others are around to help out. I thought I was steering Mud in the wrong direction.
Old 11-12-2009, 09:56 AM   #37
I really do appreciate all the help from everybody hear.Honestly!The locking spring on the actuator was gone, and the only way u can get a NEW one is to buy the whole new actuator. SO, i went and bought 2 clips like the ones you put on your hitch pin, and put them both in the springs place.THere is NOW WAY that shift cable is pulling out of those.
I dont know what rod I should be checking to see if it is going in and out?
Old 11-12-2009, 10:13 AM   #38
Well the only thing I can think of is the rod in the tube that moves the fork. pictured as #10 in that diagram.
Old 11-12-2009, 11:33 AM   #39
Rago's Avatar
I found a great pic on the web & circled the rod I was talking about:
Old 11-12-2009, 05:08 PM   #40
ok now i know what you are talkina bout...Thanks for that picture. When i took it all apart to look at the actuator that rod wasnt even hooked in, because that spring was missing. So, pretty much all i have to do is have someone press the button and see if that is moving. What if it isnt?and what if it is?
