| Junior Member Join Date: Jan 2008 Location: Northern Ontario
| I have replaced rear rotors calipers and brake pads on my 2003 chevy 2500hd....and it still is heating up too hot to touch, Truck started to jump when braking so these changes have been made. Can anyone tell me what would be the cause of them to heat up to the point of catching on fire....that was the first time. |
| Senior Member Join Date: Sep 2009 Location: MIchigan
| Sounds like the calipers are still dragging did you clean and anti-seize the slider bolts when you replaced the calipers?
__________________ THEY DON'T BUILD THEM TO BE EASY TO WORK ON THEY BUILD THEM TO WORK "The Kamikaze" |
| Is the parking brake cable hanging up? Since it's only the rears this is happening to, my initial thought was "parking brake problem". Make sure the cable releases fully, and that the pedal comes all the way back up when released.
| Gee wiz never even thought of that bernie good catch
| Thanks. It may not be the problem, but since this seems isolated to the rear brakes only it's a logical thing to check.
| I'm with Bernie that is what I would check first along with the sliding pins/bolts. If the problem still persists you might have a faulty proportioning valve.
| Senior Member Join Date: Mar 2007 Location: Pennsyltucky
| the brake hose that goes from the frame to the axle is probably bad. thats my guess.
__________________ Joe 89 K2500 Chevy, Wee-Oh-five 294K miles 1962 Scout 80 parts I guess 1966 Scout 800 resto job 2005 Chevy 2500HD Short cab long box DURAMAX 1996 P30, 6.5 NA Mac Mobile whole lot of buicks |
| flush the brake fluid, it may be getting thick!
| My Brother had the same problem. It was the rubber brake line coming off the caliper. Even though it looked excellent on the outside, the rubber on the inside had swelled and wouldn't allow fluid to return.
| 2004 silverado 2500hd rotors - stuck | JohnD | Chevy Truck Forum | 7 | 07-24-2009 10:00 PM |
| How much should I pay for a 2003 Chevy 2500HD? | Lonesome7.3 | Chevy Truck Forum | 9 | 07-19-2009 03:59 PM |
| 2003 chevy 2500hd | brandpeto | Truck Classifieds | 0 | 03-28-2007 05:43 PM |
| 2003 Chevy 2500HD 4x4 | fireman649 | Truck Classifieds | 0 | 09-11-2006 06:28 PM |
| 2003 Silverado 1500HD Brake Rotors | samsonsdad | Chevy Truck Forum | 8 | 07-12-2005 08:05 PM |
