Old 11-12-2009, 08:10 PM   #1
SkippyDoodle is on a distinguished road
Question Starting/throttle problem with '98 S-10
I am having a problem with my 1998 Chevy S-10 4.3l V6/4x2
The problem started without any warning when I turned it off and it wouldn't start back up. I had it towed it to a friend's house. I sprayed ether and it started up and stayed running well for a week.
Today it happened again. I shut off the truck and it wouldn't start back up again. I tried ether again and now it starts but won't go above an idle.
While its running I can hear a loud vacuum noise from the top of the throttle opening (the back side top). When I stick my finger down in the hole (don't know what it's called but it's a throttle port on top of the engine) the idle smooths out. When I take my finger out it idles roughly again and stalls out.
Any thoughts on what it might be, what I might check? I need to fix this fast since it is our only vehicle right now.
SkippyDoodle is offline   Reply With Quote
Old 11-12-2009, 08:30 PM   #2
silverhairdeere's Avatar
can you post a picture , it could be anything from brake vacuum booster hose to a egr hose .
shd
Old 11-12-2009, 08:36 PM   #3
shd
Thanks for responding. My husband is the one with the truck problem and he doesn't have access to a computer b/c he is staying with friends this week. He explained the problem to me and I wrote the post. I will see if he can send me a photo in the morning.
Any other thoughts for now?
He said it is not the two things you mentioned because the sound is coming from the metal part of the throttle body.
Old 11-12-2009, 10:33 PM   #4
hotrodpc's Avatar
Sounds to me he is sticking his finger down the throttle body where he may have an internal vac leak.
Old 11-12-2009, 10:37 PM   #5
So, would there be a particular part which might need to be replaced, or would he have to do some kind of test to pinpoint the problem? What would you suggest he do next to trouble shoot?
Old 11-13-2009, 11:13 AM   #6
Lightbulb The answer
It's fixed!
It turned out to be something simple and it is a little embarrassing, but to resolve this thread I need to fess up. It was the fuel filter. I didn't check it because the truck ran great before it wouldn't start the other day.
It just goes to show that the simplest answer is usually the right answer.
1987 throttle body fuel pump problem wojeepster Chevy Truck Forum 11 10-28-2009 01:53 PM
Starting problem rcrick0 Chevy Truck Forum 7 07-26-2008 02:54 PM
96 ram starting problem moparman7896 Dodge Truck Forum 0 06-24-2008 02:01 PM
problem starting Nates01Ram Dodge Truck Forum 5 06-05-2008 04:07 PM
99 S10 2.2l PU Starting problem JMP99S10 Chevy Truck Forum 3 05-06-2007 03:28 PM
