Old 11-13-2009, 07:57 AM   #1
Black Truck is on a distinguished road
ABS Light turns off and on (92 Suburban)
The ABS light comes on and off when driving. Where do I start to correct this problem? Thanks for all the help so far.
Black Truck is offline   Reply With Quote
Old 11-13-2009, 08:48 AM   #2
eponator's Avatar
eponator is a splendid one to beholdeponator is a splendid one to beholdeponator is a splendid one to beholdeponator is a splendid one to beholdeponator is a splendid one to beholdeponator is a splendid one to beholdeponator is a splendid one to behold
Best thing is to get it scanned by a shop. A normal code reader can't pull ABS codes and you can spin yourself in circles trying to figure it out without a scan.
Some guys who know the truck more might chime in with likely causes but I would still suggest you get it scanned or it could turn into an expensive repair quickly.
'99 F350 5.4L crewcab Longbed
Old 11-13-2009, 09:02 AM   #3
Case 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud ofCase 7230 has much to be proud of
If you mean that the light flashes all the time my guess would be that you have a bad fuse.
Old 11-13-2009, 09:07 AM   #4
eponator's Avatar
Heh oh yeah, if that's the case check your fuses first but if it stays on and then off for a good duration I would scan it.
Old 11-13-2009, 09:54 AM   #5
1500cheyenne96's Avatar
1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold
The problem is most likely caused by one of four things a blow fuse a faulty connection at the ABS controller a faulty connection at one of the wheel speed sensor connections or a faulty wheel speed sensor. Check the fuses first in none are blow then check and clean the connection at ABS controller disconnect battery first then pull ABS controller connection and clean. then check and clean wheel speed sensor connections the connections for these are located on upper a arm or the mounted to backing plate if you have done all this a still have a problem with ABS light you will need to get it scanned to see if you have a faulty wheel speed sensor. do you know if this truck has the 4 wheel abs or not?
THEY DON'T BUILD THEM TO BE EASY TO WORK ON THEY BUILD THEM TO WORK
"The Kamikaze"
1500cheyenne96 is online now   Reply With Quote
Old 11-13-2009, 10:56 AM   #6
Not sure if it has 4 wheel ABS.
Old 11-13-2009, 01:02 PM   #7
if 4 wheel ABS, you will have a set of wires going to each hub assembly. all 4 hubs, i mean. if only on the back and not the front, than you have rwabs or 2 wheel ABS.
Old 11-13-2009, 01:11 PM   #8
Hey thanks for clearing that up brad i kinda forgot to mention that in my rant above
"The Kamikaze"
Old 11-14-2009, 01:55 AM   #9
I assumed it was the RWAL system, so a bad fuse.
Old 11-14-2009, 08:44 AM   #10
lukasmcdukas's Avatar
lukasmcdukas will become famous soon enoughlukasmcdukas will become famous soon enough
my ranger would do that when the brake fluid level got low, oddly enough... make sure your reservoir is full.. if its not, refill it and check for leaks. im not sure why a low level made the abs light come on, but it dont cost ya nothin to check it...
Lukas "don your headdress" McDukas
97 Nissan D21 Hardbody SE Kingcab (77,500k)
86 Yamaha Maxim X 750 4 cyl, 4 stroke (48k)
Check engine light 92 suburban Black Truck Chevy Truck Forum 38 12-07-2009 11:04 AM
89 suburban TBI - from **** still DUMPS FUEL+timing light wont work grandpas68 Chevy Truck Forum 9 11-01-2009 01:35 AM
Anti-lock Brake Light 1999 4x4 Suburban Mr. Abrasive Chevy Truck Forum 0 02-27-2007 09:46 AM
94 Suburban Engine Light superdave Chevy Truck Forum 6 03-30-2006 10:15 PM
