| | #11 |
| trying to find the cable for my camera so i can upload the video so you guys can help figure it out. |
| | #12 |
| could it be a case of overtightening? i overtightened the belt on my toyota once and it squealed worse than when it was loose.just a suggestion.
__________________ Lukas "don your headdress" McDukas 97 Nissan D21 Hardbody SE Kingcab (77,500k) 86 Yamaha Maxim X 750 4 cyl, 4 stroke (48k) |
| | #13 |
| over tighten the belt? you can tighten the belt? i dont the the tightness on the belt tensioner bolt effects anything does it? |
| | #14 |
| Senior Member Join Date: Nov 2008 Location: SO Cal
| Depending on the vehicle they can come with a manual belt tensioner or an automatic (spring loaded) belt tensioner. I have no idea which your vehicle has but if proper tension isn't present squealing will occur. Do you know if you have a automatic tensioner or do you have to wrench on a bolt to get the belt to tighten up??
__________________ '99 F350 5.4L crewcab Longbed |
| | #15 |
| i have to take a pipe wrench or or channel locks to turn the tensioner to remove the belt. |
| | #16 |
| are you sure you have the right length belt?
| | #17 |
| That doesn't sound good... You should be able to move it easier than that, simply using a wrench.
| | #18 |
| well no i just need something large to grip it with it doesnt take much to turn it. and i didnt install the last serpentine belt. we had it done by a mechanic. (didnt own it at the time) |
| | #19 |
| Sounds like you got the automatic tensioner then, do you notice this moving back and forth as the engine is running? A loose or weak tensioner in this case could lead to this sound.
| | #20 |
| yea its doing it again and its a brand new tensioner. it wiggles a little again. what could be causing this? it cant be the tensioner it has to be something else causing the tensioner to fault? |
| squealing sound on start up | uranium67 | Toyota Truck Forum | 6 | 08-29-2009 10:04 AM |
| 350 belt without ac | 88chevy350ss | Chevy Truck Forum | 10 | 03-06-2009 11:13 AM |
| 96 fan belt Q. | cturner41314 | Nissan Truck Forum | 1 | 10-22-2008 09:37 PM |
| serpentine belt squealing | ray gregg | Ford Truck Forum | 3 | 03-01-2007 04:54 PM |
| 93 toyota pu 4cyl knocking and squealing??? | spacoli | Toyota Truck Forum | 17 | 11-08-2006 01:54 AM |
