Old 12-10-2004, 09:05 PM   #1
Keith23 is on a distinguished road
Problem starting
I have a 88 1500 silverado. I have a problem getting my engine to start. It turns over, but just won't catch. If I leave the throttle alone then it spurts every rotation or so, but if I hold it at WOT then it just turns over and over with no spurts.
The timing is set a 0 degrees, and the only thing I can see that may be wrong is that it looks as if the injectors are dripping and not spraying.
Any help is appreciated.
Keith23 is offline   Reply With Quote
Old 12-23-2004, 10:29 PM   #2
whitebowtie is on a distinguished road
I would check pressure at fuel rail. Kinda sounds like a bad fuel pump. But could be injecter stopped up. When you first turn ignition switch to run position, can you hear the fuel pump running? If not thats probably your problem. Its located in the fuel tank.
whitebowtie is offline   Reply With Quote
Old 03-05-2005, 08:51 PM   #3
1990_SIlverado is on a distinguished road
Hey I had this same problem with my 90 silverado. I thought it was the fuel pump but it was actaully the fuel pump relay switch. Try replacing it, it only costs abotu $15. Also clean up ur cap. Mine was relay corrodide, i replaced it and now it starts like new
1990_SIlverado is offline   Reply With Quote
Old 03-10-2005, 09:43 PM   #4
bigmudr is on a distinguished road
you set your timing at 0 degrees?? ive never seen one set so late. most are set about 10 degrees btdc. setting it at 0 doesnt allow the fuel enough time to combust like it should. but then you may have an exception ive never heard of. try adjusting it before you buy new parts.
bigmudr is offline   Reply With Quote
U-joint problem JJTRUCK Chevy Truck Forum 4 09-23-2005 12:08 PM
Diesel problem jgn Dodge Truck Forum 2 06-01-2005 05:22 PM
fueling problem Bob k Ford Truck Forum 1 04-14-2005 04:02 AM
acceleration problem ekellner Chevy Truck Forum 2 12-17-2004 09:51 AM
Committees Set Out to Solve City Truck Problem (Fort Wayne News Channel 15) trucknews Truck News (headlines) 0 10-08-2004 09:30 AM
