Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: 1991 Chevy K1500 4X4 Pickup 4.3 V6, 4 wheel drive won't engage...
    Aug 2009
    194
    Blog Entries
    1
    I have a 1991 Chevy K1500 4X4 Cheyenne 4.3 V6, New Process 241 transfer case. Last week 4x4 was fine. This morning pulled lever down to 4high for 4x4, lever locked in, the 4x4 lights did not turn on and only the rear tires spun. Drove it in reverse, forward, took it around the snowy block several times, reverse drive routine, no dice. No 4x4 working....
    I locked into 4 low, it worked. 4 HIGH will not work no matter what I did.
    Any suggestions? Thanks
    email: awbmaintenance@yahoo.com
    Kennyray's Avatar
    Oct 2005
    Fort Wayne, IN
    1,716
    I would say it is the ball switch on the T-Case or your selector is worn on the side that hits the ball switch when activating 4-hi
    2008 Silverado LT
    2009 Buick Enclave CX
    Mar 2008
    N.Y.
    10,788
    Blog Entries
    1
    put a bypass switch in the wires to the tranny ball switch and manually engage it
    Aug 2009
    194
    Blog Entries
    1
    ball switch? not sure what you mean? actuator switch maybe or is the switch actually called ball switch?
    should I replace the switch, take it out, clean it, etc.
    thanks
    Aug 2009
    194
    Blog Entries
    1
    I wanted to add a few more questions.
    Why does the 4low work and not the 4high?
    Is there a ball switch for the 4low in the transfer case?
    Is there a ball switch for the front differential?
    I researched the replacement transfer case ball switch and it says for automatic trans. it should be a three prong plug. Does any other part of the 4 wheel drive system have sensors, ball switches, vacuum switches, etc. Is my 91 chevy k 1/2 ton truck a vacuum transfer case system or something else?
    Thanks again.
    Ford= Found On Road Dead
    Ford= Fix or Repair Daily
    Than again it's my chevy that has the rear wheels spinning in the snow while the front one's are frecken useless....
    Senior Member batty1214's Avatar
    Nov 2008
    Vernal Utah
    2,269
    Im willing to bet that the front diff actuator is dead...... When you engaged 4 low, did it bring the lights on the floor on? It should have dropped the range, and made it the lower range..... but, If the light didnt come on on the floor with it in 4 low, or 4 high, I'll bet its the front diff actuator
  7. #7
    Aug 2009
    194
    Blog Entries
    1
    The floor light did not come on. Also, I just thought of checking the 4x4 25 amp fuse. I found it blown!! I replaced it with another 25 amp fuse, locked it inot 4x4, blew again! Why would the fuse blow?
  8. #8
    Mar 2008
    N.Y.
    10,788
    Blog Entries
    1
    check the wiring for a short to ground, unplug the actuator and see if the fuse blows, if not the actuator may be shorted. otherwise look around the tranny for a rub on the wires
  9. #9
    Nov 2008
    Vernal Utah
    2,269
    Like Leo said, you have a short in the wiring somewhere......... go through the steps he talked about, and you'll find your problem.....It may be the actuator is shorted..... I once had a plug on the actuator back out enough for ice to build uop inside it, and it started blowing the fuse...... check your wiring hopefully its just a cheap and easy fix..... although an actuator isnt too much, and its way to easy to replace
  10. #10
    Aug 2009
    194
    Blog Entries
    1
    Your all correct!! I unplugged the front axle actuator plug, replaced blown fuse and the fuse did not blow. As soon as I plugged in the sensor and started the truck, engaged 4x4, the fuse blew!! I replaced the front axle actuator, replaced the fuse, 4x4 working and ready to rip white powder! Excellent Chevy Forum!
    Stay American, Buy American, even if you drift to a foreign car, keep the real deal somewhere on the property. American Made Chevrolet!
  1. 05 chevy 4 wheel drive problems
    By scott500 in forum Chevy Truck Forum
    Last Post: 12-20-2012, 06:50 AM
  2. 1991 Chevy 3/4 ton, 2 wheel drive, extended cab
    By kyburzca in forum Chevy Truck Forum
    Last Post: 08-31-2009, 12:21 PM
  3. 1991 Chevy K1500 4X4 4.3 V6, Body work, parts etc....
    By awbooth in forum Chevy Truck Forum
    Last Post: 08-20-2009, 07:23 PM
  4. 1/2 ton to 3/4 HD frt brakes 88-98 Chevy or GMC 2 Wheel Drive
    By wildonev1 in forum Chevy Truck Forum
    Last Post: 11-24-2007, 11:22 AM
  5. Wheel Drive Problems 96 k1500
    By MORROWMUDDER in forum Introductions
    Last Post: 03-19-2007, 08:57 AM
