Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: 1995 chevy manual transmission fluid?
    Jan 2010
    4
    whats the name of the manual tranmission fluid for a 1995 chevy pickup 5speed. my book says GM 1052931 man. trans. fluid or equivalent, a few people told me ATF, which seems crazy for a manaul & i've also read gear-oil 75-90??
    Nov 2009
    winchester, va
    4,173
    manual uses hydro fluid like same fluid in a hydro clutch.
    Jan 2010
    4
    ?? so the same fluid that i put in my clutch cylinder
    Mar 2008
    N.Y.
    10,816
    Blog Entries
    1
    use the gm part # it has special additives so you don't smell the oil when it gets warm
    Mar 2008
    N.Y.
    10,816
    Blog Entries
    1
    [quote=jennifer_rose;148489]?? so the same fluid that i put in my clutch cylinder[/quote
    check the part numbers, i believe they are different
    Jan 2010
    4
    gm1052931 does not mean anything to the chevy department. it pertains to a part not a fluid. he said some fluid that started w a S?? sorry cant remember. i want to know if i can go to advance auto or orielys and get an equiv. and if so what is it. ive been told like 4 dif. things now
  7. #7
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    might call a trans rebuild shop. they should know.
  8. #8
    Senior Member semocoachworks's Avatar
    May 2009
    rapid city, sd
    967
    These are the ONLY lubricants recommended for the NV4500:
    • 75W-90 Castrol Syntorque Synthetic
    • Mopar Manual Transmission Lubricant (PN 4637579)
    • GM Transmission oil (PN 12346191)
    • NOTE: Syntorque is NOT the same as Castrol Syntech
    This is for the nv4500 5 speed. If it's a new venture, it will have a tag on the side telling correct fluid. If you do not use the correct fluid, it WILL result in failure as these have a paper type coating on the synchros.If it is a nv3500 ,HM-290/5LM60 5-speed manual transmission - Synchromesh transmission fluid P/N 12345349
    "Why is it that when you drop a tool while working on your truck, there is always a drain pan full of oil to catch it for you?"
  9. #9
    hotrodpc's Avatar
    Jul 2008
    Moore, OK
    7,277
    Quote Originally Posted by semocoachworks View Post
    This is the correct info right here. NO, Not clutch fluid. For clutch slave and master cylinder fluid, I do believe you can use Dot 3 brake fluid. But I didn't tell you that.
    85 Sierra Classic K1500
    85 Silverado K10
    84 Silverado C20
  10. #10
    Jan 2010
    4
    Thanks for everyone for the help
  1. Transmission Fluid
    By Enraged Bacon in forum Chevy Truck Forum
    Last Post: 08-06-2009, 11:10 AM
  2. 1995 4L60E fluid question
    By blackwarbeast in forum GMC Truck Forum
    Last Post: 04-17-2009, 07:22 PM
  3. fluid ??? on transmission
    By BLK1500 in forum Chevy Truck Forum
    Last Post: 06-28-2008, 07:07 PM
  4. Transmission Fluid (for '75)?
    By Tangent in forum Chevy Truck Forum
    Last Post: 12-20-2007, 08:53 AM
  5. Transmission fluid??
    By Schrodes in forum Ford Truck Forum
    Last Post: 12-12-2005, 02:52 PM
