Old 02-01-2010, 03:50 PM   #1
ChevMan92 is on a distinguished road
Need help quick!
i was coming back from town tonight and as i was leaving my truck started making a real loud bang. kind of like the noise and the feel of when your tailgate slams down. it felt like the whole driveline moved back or something when it does it. in the past, i have felt what feels like the driveshaft squeak and then it feels like it moves back a little bit or something. i have no idea what it could be. it sounds to me like it is coming from the rear axle, but i could be wrong and it doesn't do it when the truck is shifting, it just does it randomly, usually while i'm picking up speed. anyone know what this could be? please help. its my only truck so if something major goes wrong im kinda screwed. thanks.
ChevMan92 is offline   Reply With Quote
Old 02-01-2010, 04:05 PM   #2
Crmzendrgone's Avatar
Crmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant future
Well to be sounds like it is in the axle. Could be bearings gone bad. Can you aford to pull the cover and see what the fluid looks like and the parts.
Better yet put it up on stands and put it in gear and listen along where you hear the sound then try to pin point if it is the diff or the trans.
Old 02-01-2010, 04:07 PM   #3
davbell22602's Avatar
davbell22602 is a splendid one to beholddavbell22602 is a splendid one to beholddavbell22602 is a splendid one to beholddavbell22602 is a splendid one to beholddavbell22602 is a splendid one to beholddavbell22602 is a splendid one to beholddavbell22602 is a splendid one to behold
Sounds like bad u joints
davbell22602 is online now   Reply With Quote
Old 02-01-2010, 04:08 PM   #4
Maybe check the Trans mount and u-bolts to the rearend. Or place your truck on jack stands so you can figure it out.
Old 02-01-2010, 04:13 PM   #5
the u-joints are new and the trans. mount is a good possibility. if i have to pull the diff. cover off then i have to. ill check the non-internal stuff first. i hope its just something small because it sounds bad. its def. not u-joints because it bangs hard. if the trans. mount was loose would it still do it randomly?
Old 02-01-2010, 04:55 PM   #6
gpmorgan's Avatar
gpmorgan is a splendid one to beholdgpmorgan is a splendid one to beholdgpmorgan is a splendid one to beholdgpmorgan is a splendid one to beholdgpmorgan is a splendid one to beholdgpmorgan is a splendid one to beholdgpmorgan is a splendid one to behold
i had problem once that kind of sounds like yours. i could be driving and truck would jerk especially in overdrive. thought i had drive train problem. come to find out i had moisture in my dizzy cap. would run good one minute and then it would start jerking and bumping and you could hear the drive shaft clanging when it would do this. just an experience i had. ended up being a cheap repair. by the way, what year model is that truck? i may be way off base if you have coil packs.
gpmorgan is offline   Reply With Quote
Old 02-01-2010, 05:01 PM   #7
that way my next dizzy cap is gonna be copper from summit.
Old 02-01-2010, 05:05 PM   #8
gpmorgan's Avatar
that was the original cap when it had about 55 or 60 thousand miles.
Old 02-01-2010, 05:18 PM   #9
its a 1999 gmc sierra 5.3L 4L80E trans. 4x4
Old 02-01-2010, 05:25 PM   #10
gpmorgan's Avatar
since i havent bought a new truck 1992 in a while what year did they start using coil packs? i see youve got a 5.3 i assume you have coil packs.
Need Help QUICK! Mudman88 GMC Truck Forum 6 09-01-2009 08:27 AM
Quick Question Free68 Chevy Truck Forum 2 03-20-2009 08:00 PM
Quick question for a '97 gmc Almagi GMC Truck Forum 5 12-16-2008 03:54 PM
little quick question bigz Chevy Truck Forum 28 11-27-2008 08:17 PM
i need quick help... waterloo88chev Chevy Truck Forum 9 06-08-2008 08:40 PM
