| Full Member Join Date: Feb 2008 Location: Buena Park, CA
| Power steering pump on a '92 K1500 I'm pulling the heads on my '92 K1500. It has a 5.7L. I did a little searching on the Internet, and it looks like I need a puller to get the pully off before I can remove the pump. Can anyone recommend a decent one that is inexpensive, but will not break on the first try? I'm not a mechanic. I just need something I can use the get the pulley off and back on my truck. Thanks, Daris |
| Senior Member Join Date: Nov 2009 Location: winchester, va
| autozone or harbor freight. |
| just unbolt the bracket from the engine that holds the pump on. no need to remove the pulley. |
| My truck has a big aluminum bracket bolted to the block and the head. The p/s pump appears to be bolted to that. There is another bracket that attaches to the back of the p/s pump and over the front to exhaust manifold bolts. One of the bolts for the big aluminum bracket is behind the p/s pump. I don't have the manual yet, but I don't see any way of getting the big aluminum bracket off without removing the pump. |
| Might wanna to take some pictures of it and post them so we can what your talking about. |
| you have to pull the pulley of if you want the pump to come out :-) how the heck did i forget already i just did this 2 weeks ago....... ![]() |
| I picked up a pully puller set at Harbor Freight yesterday on my lunch. I used the 20% off coupon in one of my motorcycle magazines. (That is the hot ticket, HF has been putting 20% coupons in Rider and RoadBike magazines for the past several months). I pulled the pully off the pump last night and found three bolts under it. Once I removed the pump and the steel bracket attached to the back of it, I was able to get to the front exhaust port bolts. The next job is to get the heads off. Thanks guys! |
| Power Steering Pump | benjamins100 | GMC Truck Forum | 1 | 12-28-2009 11:10 PM |
| power steering pump pulley | liftedtrucks4me | Ford Truck Forum | 1 | 12-31-2008 06:12 PM |
| Power Steering pump? | smalcol | Chevy Truck Forum | 3 | 03-04-2008 06:30 PM |
| Power Steering Pump Part | marko2 | Chevy Truck Forum | 0 | 02-06-2007 09:05 PM |
| Power steering pump?? | Cindy | Chevy Truck Forum | 1 | 04-07-2006 07:24 PM |
