Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: 92 k1500 4x4 no fuel won't start
    Full Member hi-perfcam's Avatar
    Oct 2008
    grand haven, michigan
    31
    my 92 chevy died just like it ran out of gas. I immediatly notice that i can't hear the fuel pump running. so i checked with a test light and no power at tank. then i checked the relay and it is good. if i jump a test wire from the orange wire on the relay to the grey wire, i can hear the pump come on. but even with the jump wire on it will not start. if i pour some gas down the tbi it starts right up.other than the cpu what else keeps the fuel from the tbi?? again I've checked fuses and the relay, with the key on there is no pump noise, but if you put power to it it works.
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    i would take the relay apart and sand the contact tips in it and then try. it worked on mine and its free. still working after 5or6 years. it actually threw a code but its been so long ago i forget what it was.
    Nov 2009
    winchester, va
    4,173
    I'd do a fuel pressure test. I bet its your fuel pump.
    Oct 2008
    31
    Ibought a new relay and it does the same thing so i know its not the relay with the jumper wire on the relay i can hear the pump run but i should check the pressure.seems weird that it starts with gas. maybe a clogged fuel filter??was hoping someelse already went through this.
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    i went through it with relay. could be oil sending unit. fuel pump wiring goes through it.
    Mar 2010
    Fowler Ohio
    1
    my 97 chevy did the same a few weeks ago test the fuel pump and if you need to move the truck give it a shot of ether i should start the truck and keep it running just go easy on the gas so you dont stall it out i ended up putting a test on the truck and it was my fuel pump it gave enough pressure to keep it running but it wouldnt put out enough pressure to start
  7. #7
    Mar 2010
    Fort Worth, TX
    8
    When the key is first turned ON, without the engine running, the control module will turn the fuel pump relay ON for two seconds. This builds up the fuel pressure to normal operating pressure. If the engine is not started within two seconds, the control module will shut the fuel pump OFF and wait until ignition reference pulses are present. As soon as the engine is cranked, the control module turns the relay ON, which powers the fuel pump. The control module continues to power the fuel pump during engine operation. If the fuel pump relay fails, it is backed up by the oil pressure switch, which continues to operate the fuel pump as long as oil pressure remains above 28.0 kPa (4 psi).
    That being said check your Ignition module. If it's not sending the PCM a reference signal while the engine is cranking then it won't turn the fuel pump on. It's very common for the Ignition Modules to fail, I went through several. Be sure to get AC Delco for this part.
    The Oil Pressure Sender will only keep the engine running once it's started if the relay fails. It won't disable actually starting the engine.
    1993 Chevy Z71 - 350 TBI soon to be swapped with 97 LT1
  8. #8
    Oct 2008
    31
    I'm a complete moron!!! the ECM fuse under the dash was blown.....DUH!
  9. #9
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    at least it was a cheap repair. cool
  10. #10
    Mar 2007
    Pennsyltucky
    1,143
    glad you have it fixed. my first thought was to check and see if the SES light was on..
    Joe
    1962 Scout 80 parts I guess
    1966 Scout 800 resto job
    1996 P30, 6.5 NA Mac Mobile
    whole lot of buicks
  1. 98 k1500 won't start NEED HELP!!!
    By Mcat500 in forum Chevy Truck Forum
    Last Post: 11-02-2009, 04:29 PM
  2. 92 k1500 5.7 will not start
    By THX1138 in forum Chevy Truck Forum
    Last Post: 06-07-2008, 08:49 PM
  3. 98 K1500 cranks but won't start
    By yam350yfm in forum Chevy Truck Forum
    Last Post: 05-22-2008, 08:22 AM
  4. Wifes 93 K1500 wont start
    By Dartanion in forum Chevy Truck Forum
    Last Post: 01-22-2008, 06:53 PM
  5. 97 K1500 won't start
    By Bairplayer in forum Chevy Truck Forum
    Last Post: 04-07-2007, 06:22 PM
