Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: 89 chevy 2500 wont go into overdrive
    May 2010
    8
    Question 89 chevy 2500 wont go into overdrive
    I bought a 89 silverado from my grandpa for $500, he said i'd have to get it running right though. My problem is that it wont go into overdrive, the truck just sits idle and will rev up as if it were still in neutral. When I put it in drive the truck will run but has a hard time shifting. A mechanic friend of mine said it's probably a sensor problem( at least for the overdrive). I'm not sure if the shifting is the same problem. Anyone have any ideas or things I can try?
    Jul 2009
    Central Mississippi
    4,457
    I'm assuming you have the 700R4 transmission, right?
    Jul 2009
    Central Mississippi
    4,457
    Sorry, I just noticed you said it was a 3/4 ton. I don't think the 700R4 would be in anything but a 1/2 ton.
    Do you know what transmission it has in it?
    May 2010
    8
    I would think so, sad to say this is my first older chevy truck so i'm still familiarizing myself with them. It's whatever came stock with it haha.
    Senior Member wyochimneysweep's Avatar
    Mar 2010
    Fargo ND
    315
    gas or diesel?
    Mar 2010
    Fargo ND
    315
    does reverse work
  7. #7
    May 2010
    8
    It's gas, it's got the 350 in it. It does go in reverse. All gears work fine except the drives, overdrive does nothing and drive struggles to shift.
  8. #8
    May 2010
    14
    89 chevy 2500
    Well, the '89 Chev. and GMC 3/4 vans definitely did have 700R4s in them. Got two. Also have an '89 Chev 1 ton van that has a T400 in it with the 350 TBI.
  9. #9
    Nov 2009
    Eastern Maine
    27
    I've got an 89 k2500 with a rebuilt 700r4 in it that had the same symptoms. It's time for a trip to the transmission shop.
    GL, eric
    1988 K2500 5.7TBI (288K)
    1978 K20 292CI (16K)
  10. #10
    Mar 2010
    Fargo ND
    315
    sticking throttle vavle? they have a junior shift kit that will fix the stickie vavle.
  1. 2000 Chevy overdrive
    By Tling in forum Chevy Truck Forum
    Last Post: 06-23-2010, 12:32 PM
  2. 94 chevy wont go into 4wd
    By jremington59 in forum Chevy Truck Forum
    Last Post: 10-23-2009, 11:53 AM
  3. Chevy s10 wont start
    By abk11 in forum Chevy Truck Forum
    Last Post: 08-20-2009, 01:31 AM
  4. 2003 gmc 2500 wont start
    By habsrule14 in forum GMC Truck Forum
    Last Post: 03-04-2008, 11:48 AM
  5. 98 chevy wont start
    By dirtyryder68 in forum Chevy Truck Forum
    Last Post: 01-16-2008, 08:44 PM
Tags for this Thread
