Old 12-31-2004, 06:58 AM   #1
RICK is on a distinguished road
1990 Chevy Silverado I need help
I have replaced the water pump three times and the shaft snaps before I get out of the parking lot every time. I have replaced the idler pully, spring tensioner, new pump, pully, mounting bracket, and hoses. The engine has been replaced less then 1 hundred miles ago with a crate engine what could be wrong with this.
RICK is offline   Reply With Quote
Old 01-05-2005, 03:31 AM   #2
AK Chevrolet's Avatar
AK Chevrolet is on a distinguished road
have you made sure you have your serpentine belt on the right way? and on a 90, it should ahve a reverse rotation waterpump, make sure you didnt put the belt on backwards, even if you did, it shouldnt cause the shaft to break, just cooling problems, but ive never had a shaft in the waterpump break, are you using new waterpumps or remans? and where are you buying them from? this way i know to stay away frmo them. lol
1992 K1500 6'' Explorer Pro Comp suspension lift
35x12.5x15 Pro Comp X-Terrains
PreRunner Light bar
Piaa 8360 super racing lights
Modified 350 with cam/lifters, bored .020
AK Chevrolet is offline   Reply With Quote
Old 01-06-2005, 05:28 AM   #3
Yes I have made sure that the belt is on correctly. the pump seems to work fine until I turn the wheel hard left and right. that is when you hear it whine then pop. As far as it being a new pump no its not. I have been unsucessful at locating one. every auto parts store I check with says they are no longer made you can only get reman powersteering pumps. In my first post I said water pump I ment to say power steering pump.
Old 02-11-2005, 07:20 AM   #4
chevynut is on a distinguished road
pump breakage
never had a shaft to break but if you keep turning presure after its limts you will be replacing the power steering pump next,it could be putting a strain on the belt,you may need to make sure the tension pulley is not binding
chevynut is offline   Reply With Quote
