Results 1 to 8 of 8
Thread: 89 chevy c1500 electrical issues
    Aug 2010
    St. Louis, MO
    8
    I am new to this forum and have been scanning the post a lot are similar to my issue but I have a few more problems going on, and I need some help.
    I have a 1989 Chevy C1500 2WD 350 with a 700R4. It all started a few days ago:
    Left turn signal would turn on the right side and right would turn on the left and all of the dash lights would blink with the turn signal. If I turn on the head lights I loose the turn signal and the brake lights. The break lights work with the headlights off. When the truck is warmed up the engine will die when at idle in drive and will stay running if in Nuetral or park. There are a few more issues but once this are fixed I will adress the others.
    I replaced the turnsignal cam and that fixed the blinking dash lights and the turn signals work correctly. The brake lights and turn signal still won't work when the head lights are on. The truck still dies as described above.
    So I have traced the grounds from the tail lights to the fire wall along the frame rail and everything looks good, I didn't unbolt and clean anything.
    I am now leaning towards a headlight switch but I am lost at this point. Any help would be greatly appreciated.
    Matt
    May 2010
    Prairieville, LA
    106
    to me it sounds like you have a floating ground. u have it when the headlights are off but lose it when they are switched on. i would pull the switch and jump the terminals to see if the switch is bad. if not chech the ground at the dash support bar.
    '89 chevy 1500 5.7l tbi eng code k
    Aug 2010
    St. Louis, MO
    8
    I jumped the head light switch and the head lights work but no tail lights.
    When I press the brake everything goes haywire. Brake lights won;t work with head lights on, turn signals flash opposite whatthey are suppose to but work normally when brake pedal is released.
    I have been going through the wiring diagrams for the truck but I cannot find where the brake switch is connected into the tail light/headlight circuit but I would think it should be.
    Do you think the brake switch could be bad? How do I check it?
    Thanks
    May 2010
    Prairieville, LA
    106
    remove it from the equation. pull the conector and jump the wires. while it is unhooked ohm the switch and post your findings
    Aug 2010
    St. Louis, MO
    8
    I read .4 ohms when the switch is open and when the switch is closed.
    The turn signals work properly when the brake switch is disconnected.
    May 2010
    Prairieville, LA
    106
    there you go. replace the switch
  7. #7
    Aug 2010
    Wausau Wi going to school in Granite Falls Mn.
    7
    I had the exact same problem it ended up bein a crappy trailor lights ground
  8. #8
    Aug 2010
    St. Louis, MO
    8
    Thanks guys got it fixed. It was the brake switch.
    Now to tackle the speeddo problem.
  1. 94 Chevy 1500- electrical issues
    By mancona in forum Chevy Truck Forum
    Last Post: 07-05-2010, 11:37 AM
  2. 95 C1500 Electrical Gremlin
    By apachemech24 in forum Chevy Truck Forum
    Last Post: 05-14-2010, 03:36 AM
  3. Fun Fun electrical issues!
    By Bradley in forum Chevy Truck Forum
    Last Post: 07-16-2009, 12:23 AM
  4. 1991 c1500 compression issues
    By COUNTRYBUMKIN in forum Chevy Truck Forum
    Last Post: 04-26-2009, 03:18 PM
  5. 1993 c1500 electrical shorts
    By mikefxst in forum Chevy Truck Forum
    Last Post: 09-04-2008, 12:51 PM
