Results 1 to 6 of 6
Thread: 78 chevy hood won't close right
    Full Member pc5150's Avatar
    Apr 2010
    17
    hey there my 78 chevy, the hood will not sit down all the way in the back bought new springs, thinking of buying new hinges want to some ideas first. i've seen other with the same problem on road so it must be a common issue.
    Senior Member zombie1969's Avatar
    Jun 2010
    CT
    1,016
    Its only common with people who have misadjusted hinges or aftermarket hoods and don't bother fitting it right.I don't know what hinge setup your truck has so pictures are good to post with the question.
    Sent using Boost mobile 4g htc evo.
    Apr 2010
    17
    thx for the info i'll try playing around with i more. sorry no photo's i'll try to get some,the hinges are the old 73 to i think 79 or 80 hinge and a coil spring setup.
    Senior Member 87c10slammer's Avatar
    Mar 2008
    levittown pa
    3,221
    its definity a hinge problem. i had a 73 c10 and one day i went to shut the hood and the one hinge didnt budge. buckled the hood pretty bad. spray it down with some wd-40 a couple times a day for a few days and it should work itself out.
    Jun 2010
    CT
    1,016
    If its like a 84 with the hinge bolted to the cowl and its adjusted as far as it can go it might need a fender adjust then the door because itl throw that off.Stock hoods usually fit good but the fiber glass hood I have I needed to ream out the slots with a carbide bit to get more adjustment where it bolts to the hood.
    Mar 2008
    N.Y.
    10,865
    Blog Entries
    1
    lots of penatrating oil and loosen them up first, then see what you need to do
  1. '89 K-1500 Hood Latch Broken, Can't Hood Open, Please Help
    By Chevy0024 in forum Chevy Truck Forum
    Last Post: 10-04-2014, 01:59 PM
  2. 60-61 chevy hood for sale...
    By 64shortbed in forum Truck Classifieds
    Last Post: 05-03-2012, 08:55 AM
  3. 1987 Chevy hood ornament
    By dcfd470 in forum Chevy Truck Forum
    Last Post: 05-23-2010, 06:54 AM
  4. 84 Chevy Hood Hinge Installation
    By hotrodpc in forum Chevy Truck Forum
    Last Post: 05-26-2009, 06:05 AM
  5. I need a set of hood hinges for my 67-72 chevy pickup
    By wcedgar in forum Chevy Truck Forum
    Last Post: 08-26-2008, 09:26 PM
