Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: 96 gmc jimmy won't start
    Nov 2010
    8
    Hi all, new to this message board and trying to find an answer to my major problem. Here it goes.
    I was driven my 1996 gmc jimmy w/ a 4.3 vortec engine , down the road and the truck just died on me. The truck cranks over but does not start. When cranking over, ever 5 seconds or so, the engine stops cranking like its becoming hydro locked. Checked the fuel pressure, 62 lbs. (key on), 58 lbs (cranking), seems o.k. Check for spark at coil and plugs, have spark. Changed crank shaft sensor. Truck will not fire with starting fluild with fuel pump on or off. Pulled top of intake off, spider tubes look o.k.,not burnt or broken. Have alittle gas puddling in the # 5 & 6 cylinder intakes. Seems like fuel is coming from vent tubes that are in front fuel metering body. I'm running out of ideas. Please any help will be appreciated
    Senior Moderator chevychase's Avatar
    Oct 2010
    truck forum .org
    17,553
    Blog Entries
    3
    Sounds like a timing issue. Check see.
    Nov 2010
    8
    With #1 cylinder @ tdc, pulled dist cap off and the rotor is @ #1 . Would the timing be able to go out as i was driving ?
    Oct 2010
    kalamazoo,MI
    52
    yes the timing would normally jump while ur driving but besides that when u checked for spark what color was the spark because you could have spark just not hot enough spark to ignite all the fuel, just a guess
    92 Chevy W/T 4x4 V6 32x11.50 Procomps (daily driver)
    97 Gmc Yukon 4x4 5.7 new project
    97 Chevy Suburban 4x4 5.7 old project
    Nov 2010
    8
    I checked the spark w/ a spark plug tester w/ the mini light bulb iside of it. I've been talking to some people and they are telling me to change out the fuel injector system. Not 100% sure that's the problem, costly part on a guess. Is there a sure way to test the injectors w/ the spider tubes ? BOY, I HATE TRYING TO SAVE MONEY!!!!!
    Oct 2010
    kalamazoo,MI
    52
    well i say no on the fuel injection as it didnt start with the starting fluid. Question is did it sputter or attempt to start when u sprayed the starting fluid???
  7. #7
    Nov 2010
    8
    No, just popped a few times out of the butterfly. Changed the coil today with no luck. Would the pick-up coil give you a weak spark?
  8. #8
    Oct 2010
    truck forum .org
    17,553
    Blog Entries
    3
    Could ,but usually they go their out. And most time go out when you shut engine off . Try and see . When i have to change coil i go ahed change pick up.
  9. #9
    Nov 2010
    8
    O.K. Here's a ?. What would cause a weak spark? My next step is poss buying a new computer, but I hate to spend the $130 if it's not the problem. Did I mention I hate newer vehicles
  10. #10
    Oct 2010
    truck forum .org
    17,553
    Blog Entries
    3
    Did you run a scan on it ?? Get a cel . Just wondering.
  1. 94 jimmy won't start
    By thirdday07 in forum GMC Truck Forum
    Last Post: 08-30-2010, 06:52 PM
  2. 87' S15 Jimmy - No Start / No Crank ?
    By oscar in forum GMC Truck Forum
    Last Post: 11-02-2009, 04:42 AM
  3. 1988 GMC Jimmy Won't Start
    By cheesebone in forum GMC Truck Forum
    Last Post: 04-20-2007, 05:27 PM
  4. 2000 Gmc Jimmy Quit And Won't Start
    By SUNSHINE100163 in forum GMC Truck Forum
    Last Post: 09-15-2006, 08:01 PM
  5. 2000 GMC Jimmy - Sudden No Start
    By Robert Anderson in forum GMC Truck Forum
    Last Post: 08-25-2006, 09:54 AM
