Results 1 to 6 of 6
Thread: 4 wheel drive not working on 89 Chevy
    Nov 2010
    4
    I recently had my nephew put a engine in my 89 Chevy 2500 pickup and the 4 wheel drive does not work anymore the light on the floor will not come on and it does not work in 4 low ether any ideas? Any help would be greatly appreciated as I need that truck for my snow removal business ASAP. Thanks
    Jan 2010
    Iowa
    1,746
    you need to check to see if you have power going to the actuator on the front axle. The connector could easily have been hit when the motor was put in it
    Nov 2010
    4
    4 Wheel drive
    Quote Originally Posted by Oldmech View Post
    Thanks for the idea. I checked and there is power to the actuator. Any other ideas on what I can check?
    Jan 2010
    Iowa
    1,746
    If you have power and ground to that connector then get a new actuator and screw it into your axle. The old one up and died on you. They are easy to take out and replace. You can in fact plug the new one in before taking the old one out to make sure it is going to work. As it is warmed inside it expands and engages the axle. it can also be replaced by a cable kit if you want to do away with the electronics.
    Nov 2010
    4
    I got a new one and put it in and the problem is fixed. Thank you for your help
    Jan 2010
    Iowa
    1,746
    Very cool
  1. 05 chevy 4 wheel drive problems
    By scott500 in forum Chevy Truck Forum
    Last Post: 12-20-2012, 06:50 AM
  2. Replies: 13
    Last Post: 12-28-2010, 07:04 PM
  3. 4 wheel drive on 89 k1500 not working
    By rogersr2 in forum Chevy Truck Forum
    Last Post: 02-28-2010, 09:53 PM
  4. 1991 Chevy 3/4 ton, 2 wheel drive, extended cab
    By kyburzca in forum Chevy Truck Forum
    Last Post: 08-31-2009, 12:21 PM
  5. 1/2 ton to 3/4 HD frt brakes 88-98 Chevy or GMC 2 Wheel Drive
    By wildonev1 in forum Chevy Truck Forum
    Last Post: 11-24-2007, 11:22 AM
Tags for this Thread
