Results 1 to 3 of 3
Thread: 2000 silverado heater doesnt get hot
    Dec 2010
    I put in a new heater core last winter. Now this winter my heater is working but very little heat from it. 1 hose is hot 1 is not. No control valve under the hood, guess it's inside the cab somewhere? Can someone steer me in the right direction pleez?
    Senior Member chevy_girl_85's Avatar
    Feb 2010
    Reno, NV
    Sounds like either that new core is plugged or there is still air in it. Could the hoses be hooked up wrong? Try taking off both lines and pour coolant through it to see if it is just empty or blocked
    Live Fast, Ride Hard
    Senior Member Stitz Love's Avatar
    May 2009
    North Carolina
    Blog Entries
    Welcome to the forum.
    You have probably checked your temp guage and determined your engine is running at normal operating temperature.
    If so, then I second the motion for checking that core to be certain it's not plugged up... presuming as after you installed the new heater core last year it was working to your satisfaction. ... Which if so makes it strange that now one hose is hot and the other... not so much.
    1990 Chevy Cheyenne, SB (2wd / AC) with a;
    1993 5.7 from Police Cruiser (LO-5)-(?) installed by previous owner.
    (It sat for 7 years before I bought it.)
  1. 99 silverado heater core
    By Tri-Five in forum Chevy Truck Forum
    Last Post: 06-25-2010, 02:09 AM
  2. 2000 Silverado heater control
    By schlak in forum Chevy Truck Forum
    Last Post: 11-12-2009, 12:34 PM
  3. 02 Silverado Heater Core....
    By sophiesride in forum Chevy Truck Forum
    Last Post: 11-18-2008, 07:03 AM
  4. 2002 Silverado Heater Trouble
    By jpgoodnu in forum Chevy Truck Forum
    Last Post: 02-27-2007, 03:48 PM
  5. 2000 silverado V6 heater housing
    By squirtspop76 in forum Chevy Truck Forum
    Last Post: 11-28-2006, 04:48 AM
