Results 1 to 3 of 3
Thread: 88 chevy tail light problem
    Jan 2011
    1
    Blog Entries
    1
    Unhappy 88 chevy tail light problem
    Help! I have an 88 chevy truck, "sometimes" the left tail light goes out when I hit the brake and the brake light won't come on... I thought it was a ground, or shorted wire. Replaced the rear wiring harness to both rear lights (plugs in to a 4 pin connector LH rear frame), also replaced the LH light assembly, still the same problem.. what am I missing?
    Jan 2010
    Iowa
    1,746
    you replaced the light assembly? Including the plastic board on the back of the light itself? have seen several of those die... if it isnt the board the wiring and lights plug into then its got to be a wiring problem somewhere along the line.. I assume the turn signal for the left side is also not working?
    Jan 2011
    16
    hi mechman, does the truck have aftermarket trailer hitch wiring?, sometimes if somebody spliced the wiring for the trailer hitch wiring the connection might be loose or corroded in the harness.
  1. 88 C1500 rear brake light, tail light and everything else
    By RayandTracy in forum Chevy Truck Forum
    Last Post: 02-18-2012, 11:33 PM
  2. Tail Light troubles...
    By Monte CarloSS in forum Chevy Truck Forum
    Last Post: 03-03-2010, 06:58 AM
  3. tail light problems
    By rcrick0 in forum Ford Truck Forum
    Last Post: 10-08-2008, 02:32 PM
  4. Tail Light
    By Andrew14m in forum GMC Truck Forum
    Last Post: 02-19-2007, 10:42 PM
  5. 89 Ranger tail light problems
    By dangerranger89 in forum Ford Truck Forum
    Last Post: 11-28-2005, 03:55 PM
