Results 1 to 3 of 3
Thread: 97 Silverado Heat Odor
    Feb 2011
    2
    The heat in my 97 Silverado, smells like melting crayons, and gives me a headache. Have not noticed the smell with the A/C, so presumed it was a heat related issue (as opposed to odor coming from the engine compartment or mold on A/C condenser.) Took the dash, etc. out and got all the way to the heater core (man what a job!) expecting to find something melted on the core, or a leak. Nothing on the core, no obvious leak (very minor corrosion on one tube & fins but no apparent leak.) I pressure tested the system to see if the core would leak (can't run it with all the electronics out,) but no leak. Had been losing coolant, was not obvious why. With the pressure tester pumped to 16 psi, the engine oil cooler fitting into lower left radiator fitting started to leak radiator fluid, as did the upper hose at the thermostat, and discovered the outer gasket for the radiator cap has disintegrated (replaced radiator.) Obviously, fix the known leaks. Cleaned all of the duct work from the dash, cleaned as much of the heater box as I could reach my hand into (can't take the whole thing out because A/C condenser is inside, another brilliant design,) no change to the odor. Also noticed that when plastic parts were left out in the sun and got hot, they gave off the same odor as when heat is on, has anyone else ever heard of such a problem with the 97 trucks?
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,466
    Blog Entries
    2
    What temp does the truck have when operating. Maybe ink pen , or something fell down defroster vent.
    I found french fries , ink pens , candy ect in mine. If you do figure it out let us know.
    Feb 2011
    2
    I am not sure of the temp, but I replaced the thermostat when I replaced the leaking radiator. I was hoping replacing the radiator would fix the odor based on the hope that the odor was coming in from the engine compartment, but that fix made no change (and the odor was not anti-freeze smell anyway) again, it smells almost exactly like melted crayola crayons. I did remove the dash, the heater core, and all of the duct work looking for the source, hoping that something had fallen in, but found nothing.
  1. 2002 Silverado Heat to Floor ????
    By OnlyGM in forum Chevy Truck Forum
    Last Post: 12-12-2010, 08:13 AM
  2. Odor of diesel fuel from AC
    By Wmoore in forum Chevy Truck Forum
    Last Post: 09-28-2010, 03:32 AM
  3. 99 Silverado No Heat
    By Aluminator in forum Chevy Truck Forum
    Last Post: 02-08-2010, 07:10 AM
  4. Odor Kit - GM installed
    By fbhart@wk.net in forum Chevy Truck Forum
    Last Post: 01-15-2008, 06:41 AM
  5. Ventilation Odor
    By jeffreydcaughey in forum Chevy Truck Forum
    Last Post: 01-21-2007, 12:18 AM
