Results 1 to 5 of 5
Thread: 5.3 tourque specs
    Senior Member heavychevy85's Avatar
    May 2008
    Muncy, PA
    317
    5.3 tourque specs
    going to be installing my new head gaskets on my 5.3 need tq specs on the heads and the intake any help would be appreciated thank you all
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,508
    Blog Entries
    2
    That would be 100 ft. pounds on heads and 40 on the intake.
    Get you all torque specs need be.
    Platinum Member
    Feb 2006
    michigan
    8,677
    those head bolts are a torque to yeild and a torque angle gauge is needed to do it right.
    <----just your average 5.3
    Platinum Member
    Feb 2006
    michigan
    8,677
    1. Name:  cylinder head.gif
Size:  2.8 KBTighten the M11 cylinder head bolts a first pass in sequence to 30 Nm (22 ft. lbs.).
    2. Tighten the M11 cylinder head bolts a second pass in sequence to 90 degrees using the J36660-A.
    3. Tighten the M11 cylinder head bolts (1,2,3,4,5,6,7,8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence to using the J36660-A.
    4. Tighten the M8 cylinder head bolts (11,12,13,14,15) to 30 Nm (22 ft. lbs.) . Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts
    intake is 44 INCH pounds on first pass and 89 INCH pounds on final pass.Name:  intake.gif
    May 2008
    Muncy, PA
    317
    i just baught a chiltens manuel so i belive im good to go thanks every one for the info
  1. timing specs
    By ksbs2007 in forum Chevy Truck Forum
    Last Post: 02-15-2011, 10:45 AM
  2. Help looking for specs
    By terrymac in forum Dodge Truck Forum
    Last Post: 09-17-2009, 05:01 PM
  3. Alignment specs
    By Treeman in forum Chevy Truck Forum
    Last Post: 08-11-2009, 09:17 PM
  4. BANKS tourque tubes
    By stumpuller454 in forum Chevy Truck Forum
    Last Post: 03-14-2008, 03:35 PM
  5. cam specs
    By keithr0005005 in forum Chevy Truck Forum
    Last Post: 03-13-2008, 01:37 PM
