Results 1 to 3 of 3
Thread: 83 K10 fuel tanks wont switch
    Apr 2011
    2
    Have an 83 chevy and tanks wont switch over. When I first got the truck it ran off the Drivers sidem and wouldnt switch to the pass side. I replaced the switch and nothing. Replaced the selector valve. The new valve must have been set for the pass side which it now runs off, but wont switch to the drivers side. I know both tanks are sending fuel. I also tested the wiring to the valve, had someone hit the switch while I used a test light on the plug to the valve and it is sending a "signal" to switch over. Any ideas? or could it just be a bad valve that I got from the parts store?? Wouldnt be the first replacement part I got that was bad out of the box.
    Thanks
    crabtruck's Avatar
    Jul 2007
    5,566
    Welcome to the forum.
    Believe on that truck it does not 'send a signal'
    but rather reverses the polarity of hot and ground from switch.
    If you are seeing a hot at valve, suggest you confirm ground at switch.
    Here's a related link: 1987 chevy tbi - wiring switch to dual pumps
    Jul 2009
    Central Mississippi
    4,457
    Wiring diagram for dual fuel tanks
    http://i89.photobucket.com/albums/k2...chematic-1.jpg
    The above link shows the wiring diagram for dual fuel tank setups in Chevy trucks. Like crabtruck said, I would bet the problem is in one of the grounds. I have run into the very problem (and solution being the ground) in my ride.
    Hope it helps.
  1. Will 99 and up stock fuel tanks fit my 95?
    By Lonesome7.3 in forum Ford Truck Forum
    Last Post: 03-23-2010, 09:25 AM
  2. Extended range fuel tanks
    By drbob11 in forum GMC Truck Forum
    Last Post: 02-25-2010, 12:31 PM
  3. 1987 chev fuel tanks
    By vetterm39 in forum Chevy Truck Forum
    Last Post: 10-23-2009, 08:08 PM
  4. fuel tanks swapped
    By bikernut in forum Chevy Truck Forum
    Last Post: 09-11-2009, 10:48 AM
  5. '80 GMC Sierra using fuel from both tanks.
    By JRV1811 in forum GMC Truck Forum
    Last Post: 08-12-2009, 12:11 AM
Tags for this Thread
