Results 1 to 7 of 7
Thread: 2000 Silverado 4.8 LS, Serpentine Belt
    Feb 2011
    61
    I just replaced the serpentine belt on my 4.8 V8. How do I know if the belt is to tight?
    MikeG's Avatar
    Feb 2011
    Richland, Wa
    2,195
    Blog Entries
    1
    As long as the spring in your tensioner pulley is operating properly, the tension will be where it needs to be.
    Feb 2011
    61
    this is the thing,, the tensioner after replacing the belt has maybe 1/4" of slack left. Meaning if i need to remove the belt thats how much it would release to get the belt off. I am thinking the belt is too tight.
    Senior Member greencamaro1981's Avatar
    Feb 2011
    bozeman mt
    349
    they are tight for a while wait a couple of days and check again they do stretch
    MikeG's Avatar
    Feb 2011
    Richland, Wa
    2,195
    Blog Entries
    1
    Not to insult anyones intellagence, double check to make sure the belt is placed on all the pullies correctly. I've done that myself and had slack left in the tensioner. New belt or not the tensioner shouldn't have any play in it; unless the spring is bad. I'm trying to get on the Chilton Library to pull up a diagram but the Military site is down right now. I"ll keep trying to get on and post a diagram.
    MikeG's Avatar
    Feb 2011
    Richland, Wa
    2,195
    Blog Entries
    1
    Got you the diagram:
    Belt Routings
    Accessory serpentine belt routing—4.8L, 5.3L and 6.0L engines
  7. #7
    Feb 2011
    61
    got it thank you,
  1. serpentine belt width
    By price in forum Chevy Truck Forum
    Last Post: 11-25-2008, 07:55 AM
  2. Serpentine belt
    By gmctrucks in forum GMC Truck Forum
    Last Post: 04-03-2008, 10:27 PM
  3. 98 Silverado serpentine belt problems
    By bsr101 in forum Chevy Truck Forum
    Last Post: 06-05-2007, 06:34 AM
  4. serpentine belt squealing
    By ray gregg in forum Ford Truck Forum
    Last Post: 03-01-2007, 05:54 PM
  5. serpentine belt
    By scottie in forum Chevy Truck Forum
    Last Post: 01-25-2006, 12:51 PM
