Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: 1991 Chevy 2500 starting problem
    Full Member CowboyCadilac's Avatar
    Jun 2011
    Minnesota
    23
    I have a 1991 Chevy k2500 with a 5.7 tbi. It just happened the other day where the truck just shut off like I turned the key off. Then finally got it running and it ran fine for a couple days and then happened again. Had it towed home and today put a new fuel pump and fuel pump relay and got it to start 2 times but then died and now won't start again. Does anyone have any idea where to go next?
    Apr 2011
    Tennessee
    211
    did you replace the fuel filter
    Jun 2011
    Minnesota
    23
    I did not replace the fuel filter. Wasn't exactually sure if the fuel filter could cause it to do that? It also when u turn the key is not shooting gas out of the injectors. So I guess maybe it could be a plugged fuel filter.
    Apr 2011
    Tennessee
    211
    or it could be the icm check to see if you have spark. the icm controls the injectors and the spark and they love to fail
    Jun 2011
    Minnesota
    23
    I bought a fuel filter for it today. Don't have time yet to get it put in so will post after I get it put in tomorrow. Thanks for all the help. Forgot to ad that I did go out today after it sat all night and tried starting it and it started right up. Ran for about 30 secs and then just like I turned the key off and died and wouldn't start again.
    Apr 2011
    Tennessee
    211
    try unplugging the temp sensor and starting it. its located next to the top radiator hose on the manifold
  7. #7
    Jun 2011
    Minnesota
    23
    Got the new fuel filter in tonight. Started up after priming the pump a few times. Ran for about 30 secs and died again and wouldn't start back up. Waited about 5 min and it started again and did the same thing over. Now it won't start again. Tried umpluging the temp sensor and starting it and still didn't start. So is my next option to replace ICM?
  8. #8
    Apr 2011
    Tennessee
    211
    try testing the pressure at the tbi i think it should be between 12-16 psi if you get good pressure and it still doent put out from the injectors my next thought would be icm there pretty cheap
  9. #9
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,371
    Blog Entries
    2
    When it will not start pour some fuel in throttle body.... if still no crank check for spark at the plugs... then at coil.
    If not probably be icm or pickup coil. Check resistance on the icm and pickup.
    If you get 800 to 1200 ohms of resistance they are good.
    The pickup is a old school / type of crank sensor.
  10. #10
    Jun 2011
    Minnesota
    23
    Ok so I bought the ICM today and not sure how to put it in or where it goes. Can anyone give me a heads up on how to install it?
  1. Replies: 6
    Last Post: 08-12-2012, 01:04 AM
  2. 94 Chevy silverado starting problem
    By fjsenn4949 in forum Chevy Truck Forum
    Last Post: 12-19-2010, 12:13 PM
  3. 94 Chevy Diesel starting problem?
    By LuvMyChevyTruck in forum Chevy Truck Forum
    Last Post: 12-14-2010, 08:54 PM
  4. 1988 chevy g-20 van starting problem
    By blackls6 in forum Chevy Truck Forum
    Last Post: 08-02-2008, 05:14 AM
  5. 99 Chevy starting problem
    By chevyz71 in forum Chevy Truck Forum
    Last Post: 01-24-2006, 07:27 AM
