Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By chevychase
Thread: 5 to 6 lug conversion
    Sep 2011
    1
    I want to convert my 2000 Tahoe 2WD Limited-5 Lug to late model 6 lugs. How involved is this? Which would be a perfect donor vehicle? I specifically want to run Silverado SS type 6 lug wheels on my Tahoe? How do I get started? Please help!!!
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,480
    Blog Entries
    2
    Easiest way would be with some adapters.. Could get six lug rotors up front.. either drill rear hubs .. or change axles .
    But the way to go would be adapters. Search wheel adapters... maybe summint racing . com ect.
    MikeG likes this.
    MikeG's Avatar
    Feb 2011
    Richland, Wa
    2,195
    Blog Entries
    1
    Grab a 4 Wheel and Offroad mag, there are a few companies in there that have them.
    '96 K1500 Ext. Cab Z71, 5.7L, Spectre Air Intake, 4L60E, 201K+, 13/18mpg
    My other car is Aircooled
    '69 Patina (0\_!_/0)
    Senior Member chevyguy's Avatar
    Sep 2005
    Oklahoma city
    4,094
    You can use adapters or you can do it right. Find the same year light duty 2500 2wd parts truck. Swipe the rear end and everything from the spindles out. They bolt right up to our trucks. Only odd parts is the offset u joint. Dont see why anyone would nto go this route as it would get you away from the 10 bolt rear axle that is the weak point on our trucks. I am considering doing this on my 94 1500 to get away from the 5 lug wheels adn the 15 inch tires.
    Window tint its for window, Not for tail lights. Don't be that guy .
  1. 5 lug to 8 lug conversion.
    By Towtruck in forum 4x4 trucks / off road
    Last Post: 08-20-2009, 10:29 PM
  2. MAF conversion 88 f-150
    By Painster in forum Ford Truck Forum
    Last Post: 08-09-2009, 02:43 PM
  3. conversion
    By mr.bigs in forum General Truck Forum
    Last Post: 06-18-2009, 10:41 AM
  4. 4X4 Conversion
    By Danillac in forum Chevy Truck Forum
    Last Post: 02-29-2008, 03:49 PM
  5. 2wd conversion?
    By jcmorris in forum Ford Truck Forum
    Last Post: 12-01-2007, 09:26 PM
