Results 1 to 8 of 8
Thread: 4 wheel drive problems in 2 wheel drive
    Sep 2011
    6
    I own a 84 chevy. When driving down the road in 2the wheel drive a rapid clicking sound begins to come from the front axle. It sounds like a baseball card in a bike tire. If I slow down the truck "jumps or "jults" the clicking will stop and I can continue driving. It never happens if I leave the truck in 4 wheel drive. I almost think my automatic hubs are trying to engage in 2 wheel drive. Anyone thoughts??
    Dec 2007
    1,645
    In 2hi it should not matter if the hubs do engage. However might be a good idea to dismantle them and clean and lube them. Replace any damaged parts.
    Sep 2011
    6
    If it does not matter if the hubs engage could it be the transfer case trying to engage?? Why would the clicking come from the axle area?
    Dec 2007
    1,645
    Yes it could well be the auto hubs clicking so it would be good to have a look at them. However, even if they did engage when in 2hi all that would happen is that the axle shafts, differential and the front driveshaft would start turning but would not be connected to the rear wheels. It would be no different from 4x4 trucks with no free-wheel hubs. I would check the hubs first and have a look at the axle shaft universal joints.
    Sep 2011
    6
    Ok so I pulled out the hubs, cleaned them regreased them and put them back in. There was no signs of damage or metal chavings. Took the truck out for a spin and same thing... about I mile down the road it something clicked and the same clicking sound. I think I pull some manul hubs out of a buddys truck just to see if that changs anything.
    Moderator
    Jul 2011
    Central Oklahoma
    5,339
    Being a 84 don't you have a lever in the floor to put it into 4 wheel drive? Might see if that needs adjustment or its bent trying to slightly engage 4 wheel drive. Maybe u joints up front binding?
  7. #7
    Dec 2007
    1,645
    Good that you checked the hubs. I would check what dirtrider says in case your transfer case is not fully into 2hi.
  8. #8
    Sep 2011
    3
    84 chevy
    Quote Originally Posted by ElmerJ View Post
    had the same problem with a 84 s-10, just had to unhook vacuum line to the front hubs when in 2wd
  1. 05 chevy 4 wheel drive problems
    By scott500 in forum Chevy Truck Forum
    Last Post: 12-20-2012, 06:50 AM
  2. four wheel drive problems
    By ddraszt in forum GMC Truck Forum
    Last Post: 12-17-2007, 08:42 AM
  3. Wheel Question on my 4 wheel drive???????????????
    By 92BlueZ71 in forum Chevy Truck Forum
    Last Post: 03-19-2007, 04:06 PM
  4. Wheel Drive Problems 96 k1500
    By MORROWMUDDER in forum Introductions
    Last Post: 03-19-2007, 08:57 AM
  5. 4 Wheel Drive Problems
    Last Post: 03-12-2006, 03:22 PM
Tags for this Thread
