1999 Suburban Backup / Reverse Lights Not Working
Hi,
When I shift into reverse, the corresponding lights do not turn on. Thinking maybe they were burned out, I replaced them but still no dice.
I checked the driver side dashboard fuse panel as well, all fuses are fine. Turn signals, brake lights, etc all work fine...it's just the backup lights.
My next guess is a bad wire or circuit board, but I'm not sure where to look.
I'm a novice, but if any experienced people out there tell me where to look I can probably take care of it as I'm pretty good with my hands.
Thanks in advance!
TD
'99 K1500 Suburban 4x4
It is unlikely that both bulbs would be bad but worth checking them. Not an expert but if I had to guess I would say that the neutral safety switch is bad. I would think (not 100% sure) that the NSS is at the bottom of the steering column near the floorboards.
Hopefully some of the experts will give an opinion soon.
Reason: typo
What case has said .. also could be circuit board .. had a lot of flaws in it.
By 4bnbad in forum Chevy Truck Forum
Last Post: 02-20-2011, 01:39 PM
By chrsbrgrn in forum Chevy Truck Forum
Last Post: 12-06-2010, 03:31 AM
By bigshot846 in forum Chevy Truck Forum
Last Post: 03-24-2010, 09:47 PM
By pdrutherford58 in forum Chevy Truck Forum
Last Post: 02-10-2010, 11:41 AM
By Steve g. in forum Ford Truck Forum
Last Post: 11-08-2008, 08:33 PM
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Back to Top
